[:!: Warning: armchair engineering aheadcma wrote:- New regulations to ensure that the brake discs rotate at the same speed as the wheels
Does this imply someone has implemented a system of differing rotation speeds? What benefit could be gained from this?
Depending on how you controlled it (if you could find a loophole to allow active control, or just a "useful" passive slip):
1> ABS and/or active brake torque control - would require a loophole for active control - e.g. (& I don't know of a loophole that would allow this, just an extreme example) a clutch that releases the disc from the wheel to effectively remove the brake without the pads being controlled.
2> Harvesting control on rear axle - allowing slip of the disk on the axle to balance the engine braking within the BBW system - could be a passive setup choice - harvest always at maximum in the MGU-k, modify disk slip to change engine to disk balance in BBW.
- no idea whether that would be better/worse than either controlling resistance at MGU-K for balance, or a differential splitting MGU-K braking from standard engine braking (not even sure this diff would be legal!)
3> Some degree of left/right brake torque control, e.g. inside wheel is unloaded, so de-clutches the disk from the axle slightly, reducing inside wheel locking.
- More advanced 4 wheel skid steer (brakes de-clutch on one side = skid steer on other side) might be possible, but I can't think of a legal way.
- A differential between this disks could have a locked disk counter rotating, but I'm not sure that's legal.
I'd say passive declutching of disk/axle on inside wheel sounds plausible, the rest might be a bit fanciful!
