Do all teams use water cooled intercoolers now?
Scania
Scania
in the team's 3d pic, all engine have a huge intercooler in the side pod, but in the real photo, looks like no one have it, is all team using water intercooler?
FW17
185
Re: is all team use water cooled intercooler now?
Only ferrari engines using water air intercooler
Lotus may have used a water air inter cooler but not sure.
All other teams using air - air intercoolers
mrluke
mrluke
WilliamsF1 wrote:Only ferrari engines using water air intercooler
Where is mercedes air to air intercooler?
FW17
185
I don't think there are any pictures of it.................
mrluke
mrluke
WilliamsF1 wrote:I don't think there are any pictures of it.................
I think thats the clue ;)
Mercedes W05: water-air - the intercooler is 'integrated' to the monocoque... somewhere between the engine and the fuel cell, very close to the compressor.
Lotus: water-air - low in the left sidepod.
Ferrari cars: water-air - placed in the engine's 'V'
RBR, STR and Caterham: different air-air intercoolers, one in each sidepod
IMO Williams* and FI use an air-air Intercooler (left sidepod) while Mclaren use two...
*But some people say the Fw-36 now uses a water-air one place low between the monocoque and the engine...
Somers wrote a nice article about this supject http://somersf1.blogspot.com/2014/06/po ... cture.html
Brian Coat
Brian Coat
99
Re: Do all teams use water cooled intercoolers now?
Are we about the Mercedes statements/blogs above?
I've also seen it stated/claimed (in RET, I think) that they use both water : air (hi temp, with the main coolant circuit providing the water) AND then by air : air (lo temp, in side pod).
It seems logical to me because it could possibly give an aero advantage?
Thoughts?
xpensive
xpensive
214
This looks like an ar-to-air intercooler to me, MHPE engine in the McLaren?
Q; Are the customer-teams free to select intercooler solution?
mrluke
mrluke
The customer teams all come up with their own cooling solution.
Mercedes works team appear to have by the far the best solution though, though that is true on most aspects of the Mercedes car this year.
I struggle to see how the main cooling circuit can serve an air to water charge cooler, the engines likely run at over 100deg C. Thats not going to cool the charge air very efficiently.
579
xpensive wrote:This looks like an ar-to-air intercooler to me, MHPE engine in the McLaren?
That looks like a liquid to air heat exchanger. The top tank and the pipework are too small for high volume flow.
chip engineer
chip engineer
21
mrluke wrote:The customer teams all come up with their own cooling solution.
I hope the water coming back from the radiators is much cooler than that...
I suspect the water coming out of the charge cooler then goes to the engine.
As a previous commenter wrote, doing some additional air to air charge cooling after the initial air to water may have advantages.
xpensive
xpensive
214
You are correct of course, I think I was blinded by the central manifold, but why the multiple in- or outlets, is that typical?
xpensive
xpensive
214
Is that, from top to bottom, two radiators, oil + water, and one intercooler, but the connection for the latter looks skinny?
I'm confused, anyone?
CBeck113
CBeck113
51
If I count the inputs and outputs, I see three: a very small one up top, then two further coolers about the same size, with the ports of the third on the lower corner. So, my guess is that they are top to bottom: electronics, intercooler and engine. I'm sure I'm wrong so please correct me :-)
532
A different angle on Bottas' sidepod.
