up to a point where too much negative camber causes the outside of the tread to lose contact with the pavement thus reducing contact patch size and grip.
As depicted here
Where the left side of the trad loses contact with the ground.
Does additional vertical force (like downforce) allows the tire to compress as to allow the left side of the tread to regain contact with the ground, while still generating additional camber thrust and cornering force?
Simple logic says so.
Are there some camber vs grip charts at different vertical loadings to confirm or deny this?
