F1 Wing Height 2010 - CFD
al_garnett
al_garnett
I am completing some CFD analysis on the front wing of a 2010 F1 car.
Could anyone provide me with the height from the bottom face of the endplates to the ground? I'm using a value of 50mm but this seems far too high to maximise the ground effect.
Thanks
Blanchimont
Blanchimont
214
Re: F1 Wing Height 2010 - CFD
The distance to the ground is not defined, it is the distance to the reference plane(75mm). But below the RP there is a 10mm thick wooden plank. If the car would rest on it, the distance to the ground would be 85mm.
But with 1° rake added to the car, the front wing comes down by ~ 1330mm*1°/180°*3,14 = 23,2mm
If we now add the fact that the FIA allowed a flex of 10 to 20mm(see the link below), this makes a ground clearance of 85-23,2-20 = 41,8mm at the endplates and 85-23,2 = 61,8mm in the middle. With higher rake angles and more flex these numbers change, of course.
http://www.formula1.com/news/technical/ ... 6/782.html
