Hi, newyorkkopter. I'm kind of firing from the hip here, but I'd say no.
Actually, trying to get the benefits of a wider track from wider/expanded/modified rims is one of the marks of the ricer beast, if you follow my drift. Along with fake engine noises, large wings, body kits and decals from other cars...
If you don't mind having no suspension, then wider/expanded tyres are the bees knees
There are several disadvantages.
Depending on how you increase your track, sometimes wheel or wishbones bearings would be subject to greater forces.
Sometimes, tyres would bump into the body.
Sometimes people try to compensate with negative camber (tyres would look like this: "/\"), making things worse.
Another thing is more unsuspended mass, heavier steering, a bit less acceleration because of the added rotational mass (if the extensions are fixed to the rims, clearly), changes in balance of under/oversteering, etcetera, etcetera.
I've seen (and given my condolences to) cars that can't even turn the steering wheel fully in either direction without the tyres rubbing.
However, yes, you'd have less lateral roll, specially if the body hits the tyres.
Do... not... steer... this... car!
