Scuderia Ferrari SF15-T
Re: Ferrari SF15-T Pre-Launch Speculation Thread
Slight pelican on the nose.
FrukostScones
162
I like!
VET WDC 2015! Who saw that coming?
i70q7m7ghw
i70q7m7ghw
49
Still stubbornly sticking with pull-rod on the front. It does look like a very refined configuration now though.
Pilatus
22
outsid3r wrote:this looks somewhat interesting (and innovative?) horizontal grills which seem to channel air to the vertical ones from within the spoiler
http://s27.postimg.org/rkyq4e45v/3_4_RETRO_2015_OK.jpg
And where are the vertical gills ond the left endplate? :?:
It looks like they've gone quite a bit lower with the front wishbone and pullrod points - that should help with any stiffness issues at the front of the tub, and also with the front mechanical grip, which is exactly what Kimi needed, so although I see the pullrod haters are back screaming it'll never work, it does look like they've pushed it more towards what the drivers needed this year.
FrukostScones
162
camera angle
Kiril Varbanov
147
Inevitably, the comparisons are here:
Pedrolito
It's hard to see, but in some pics, it seems there is a "bulb", protuberance or air intake under the nose.
integrated front tie rod too.
SectorOne
It´s interesting to see the big names in the sport have all gone quite sanitized, very careful and very basic so far.
If that means all of them are pretty solid cars then we are in for a treat in 2015.
Kalsi
Kalsi
31
The nose looks very good... and Pull rod suspension had a very important part for making it possible
The very low nose angle is was only possible by not having a push rod attached that high on the shassis like the W05 for example... which have a vary short nose with it's slope starting after the push rod
I don't think Pull rod was a problem for ferrari in the past years but finally looks like it is a good solution for this year's regulations
As for the diapason style adjustments, that could fix kimi's problems and general understeer
Very big changes on the rear suspensions too makes me hope for a better traction (real f14-t problem)
Im confident!! As i was with the f138 .... let's just hope for no pirelli-gate this time
Blown wheel nut at the rear? curious.
f1316
f1316
78
gandharva wrote:
Thanks. I was in the process of generating the same comparison. Yours came out just as I expected. 2015 Ferrari is still quite a fatty around the hips and ass. Din't they say that the back will be much slimmer?
The very back of the McLaren is obviously slimmer but it's also interesting to see the shape that brings them to the central point - the Ferrari follows a much smoother curve.
Equally, I'd be surprised if there was anything at the back of the Ferrari that prevented them creating that central 'v', more that they consciously chose to use have the bodywork extend right to the diffuser to help prevent separation.
None of which is to say one is better than the other, it's just a slightly different philosophy.
