rotary? turbine? 2 pot quad turbo??? anything!!!
personally i would have a single turbocharged V10, because i love the old screamers but combined with that turbo whine, that would be mega.
so come on guys what dya think???
Not really, it would be less than 1L to be light and get reasonable fuel consumption...wuzak wrote:A V10 and turbo would surely be heavy?
Twin turbo with current MGUH is impractical. And without the fuel flow limit and just a max rpm you have no restriction on power. And without a boost limit you are almost guaranteeing lower rpm. If you want them to rev to 18,000rpm yu would need to have a low boost limit to force them to use extra rpm.maguetox wrote:My ideal would be V12 with no RPM restriction, but like this is not going to happen and to make it fast without to much of an additional investment from the manufactures:
1.6L, V6, twin turbo.
Max RPM: 18000
Max tank fuel capacity: 140 liters
Max fuel flow rate: no restriction, free fuel flow.
Fuel injection: Direct injection, single injector per cylinder, 500 bar max
Same Motor Generator Unit - Kinetic (MGU-K) as today reg
Same Motor Generator Unit - Heat (MGU-H) as today reg
Max Energy Store (ES): 5 Mj per lap
I largely agree, but with the fuel flow limit, why have any restrictions on capacity? Maybe require at least 4 cylinders, but any configuration (linear, V4, V6, opposed 4 or 6, or V12 if someone wants).wuzak wrote:Twin turbo with current MGUH is impractical. And without the fuel flow limit and just a max rpm you have no restriction on power. And without a boost limit you are almost guaranteeing lower rpm. If you want them to rev to 18,000rpm yu would need to have a low boost limit to force them to use extra rpm.maguetox wrote:My ideal would be V12 with no RPM restriction, but like this is not going to happen and to make it fast without to much of an additional investment from the manufactures:
Max RPM: 18000
Personally I would keep the fuel flow regulation and dump the race fuel allowance. Since the target is 1000hp I would dump the rpm limit (they won't go too high anyway) and maintain the fuel flow formula (rpm * 0.009 + 5.5) but have the fixed flow rate start from 13,000rpm (122.5kg/h).
The maximum capacity would be retained, but there would be no minimum capacity.
No development limits, but a limit to the price that engine suppliers can charge clients.
Allow more ICE per season. Electric gizmos and turbo should last longer, so they can stay at 4/season.
I wouldn't change the ES regs, except I would remove the weight limits. So if a team want sto run less storage and less weight they can.
Minimum weight and minimum CoG can go.
Ditch the requirement that the exhaust must exit on the outside of the vee.
Allow V8s and V10s of the previous two engine formulae to compete with smaller teams, using the 122.5k/h fuel flow limit (but not the formula) and no rpm limit.
How much power do you think they need?PlatinumZealot wrote:ENGINE TYPE AND LAYOUT
Fuel flow limit: 220kg/hr
So perhaps 25k rpm when overtaking?bidong wrote: RPM to be limited to 22,000 rpm. No rpm limit for 8th gear when 1 second behind . . .
exactly...gruntguru wrote:So perhaps 25k rpm when overtaking?bidong wrote: RPM to be limited to 22,000 rpm. No rpm limit for 8th gear when 1 second behind . . .
