Downforce calculation Equation
al_garnett
al_garnett
Hey guys,
The following formula is provided on the wikipedia page for downforce,
D=0.5(WS)*H*alpha*F*rho*V^2
Where:
D is downforce in newtons
WS is wingspan in metres
H is height in metres
\alpha is angle of attack
F is lift coefficient
rho, ρ, is air density in kg/m³
V is velocity in m/s
Does anybody know the source of this Formula or how its is derived? I need to reference/cite it for a university project but can't find it anywhere. We are not able to reference wikipedia articles.
Thanks
Greg Locock
Greg Locock
238
Re: Downforce calculation Equation
I suspect it is fanboi rubbish
NoDivergence
NoDivergence
50
This is called the lift equation, maybe sometimes referred to as the lift formula. Only thing I don't agree with is the alpha.
L = 1/2 rho V^2 S C_L
where S is the planform area, and rho, the density of the flow
Downforce is the same as lift except the sign for C_L will simply be negative.
Cold Fussion
Cold Fussion
93
That is a very strange way or writing the lift formula and I wouldn't say is correct. The lift coefficient depends on many things, one of them is angle of attack and height above the ground, so why is then in main lift formula? In any case that formula wont give you a force at the end of it. You should use the formula that NoDivergence posted.
al_garnett
al_garnett
NoDivergence wrote:This is called the lift equation, maybe sometimes referred to as the lift formula. Only thing I don't agree with is the alpha.
However a wing runs in ground effect which raises downforce generated. If the formula is used, finding the lift coefficient from a cfd experiment, without the wing in ground effect, and the result compared to a cfd simulation where the wing is modelled with the road below. The results are close enough to be called the same.this seems to suggest the formula does work.
Greg Locock
Greg Locock
238
seriously, when the formula claims WS=wingspan? So the geometrical scaling dimension is wingspan * height(presumably off the ground)?
I doubt alpha has any directly linear relationship with THAT.
CBeck113
CBeck113
51
>>Edit: Greg was right, and this was sh*t<<
Here is a link for a better explanation of the lift equation:
http://www.ppl-flight-training.com/lift-formula.html
Greg Locock
Greg Locock
238
um, no, it just looks a bit like that
Cold Fussion
Cold Fussion
93
That's not how that formula will work though. That will give you increasing downforce with increasing height, which doesn't make any conceptual sense. The proper way to evaluate this is group it all into the coefficient of lift.
Tim.Wright
330
Looks like they are using the basic lift formula but replacing the frontal area with WS x H which for a rectangular section is the frontal area. I also don't understand the alpha though. I think its an error.
The whole article seems a bit crap which is often the case when automotive engineers try to reinvent the explanation of certain physical effects rather than using good old classical mechanics.
On that note, if you insist on using wikipedia - at least use the more general page for "aerodynamic lift":
http://en.wikipedia.org/wiki/Lift_%28force%29
Blanchimont
Blanchimont
214
If F is the slope (Cl/AoA) in the linear range in a plot like this
then the formula can be used in the linear range for a symmetrical foil. I would replace WS*H with the wing surface seen from above.
[D] = [m*m*rad*1/rad*kg/m³*m²/s²] = [m*kg/s²] = [N]
Greg Locock
Greg Locock
238
So how different would that curve be for a multielement heavily cambered short wing with end plates, operating at or beyond the stall point, in a highly variable flow?
NoDivergence
NoDivergence
50
Completely and totally would depend on the flow and geometry and location of the main element and flap/slats.
I would guestimate that Cl_alpha would be above, but somewhat near 2pi/radian (likely around 7/radian for a conventional slat/main/flap airfoil) in the linear region, but past that, trust me, who the hell knows.
Using alpha in the lift equation makes absolutely.
panayiotis
panayiotis
Re: wheel base
can anyone knows where i can find the wheelbase, rear and front track. also the weight distribution. only for 2014 f1 cars...thnx in advance
SpainFAN
SpainFAN
AoA is fix as is the wing, unless you are varying the AoA, that's why C_l is used. An airfoil, and therefore a will will have a CL envelop with C_lmin-C_lmax at each extreme.
A multielement wing is just that, a multi-element wing, which would a its own C_l at a given AoA for a given airfoil.
Multi-Element is BTW the best way to gain higher C_l in a given wing. Most aviation application is useless because of limits in build technology to get wing span load distribution. there was a glider that had very short wing span, utilizing multi element wing at the tips.
Endplates are a highly debated subject by aeodynamicist...
