I was just reading about a team in Sweden who have designed a new sort of skin for aircraft wings. Bits of the article are as follows:
The performance-sapping turbulence of air passing over aircraft wings can be suppressed by carefully designed roughness in the surfaces.
Turbulence is associated with increased friction drag, the resistance of a thin body when it slides past slower moving air. Delaying turbulence is important to decrease the drag. Conventional view is that to minimise turbulence, wings need to be extremely smooth. Aerodynamic specialists have also considered actively controlling turbulence through complex and costly mechanisms such as continuously sucking the turbulent air through holes in the wing to pull smooth airflow towards the surface. A more recent suggestion is that rough surfaces could actually help control turbulent airflows.
They found that covering a smooth surface with a series of small pill-like discs, each just 1.4millimetres high and 4.2mm across, can actually delay or inhibit the onset of turbulence, reducing dragby up to a factor of 10. The discs create tiny whirlpools of airflow. These weaken and smooth out the bigger airflow disturbances around the aircraft skin, which would otherwise rapidly grow to produce turbulence. (NewScientist, March Edition)
Anyways, i was just wondering if this could applied to the front/rear wings of an F1 car?? or if not even the 'sucking holes' idea that was mentioned? (has that already been tried and banned??)
I'm sure that the turbulences that are experienced by an aircraft wing, (due to its speeds) far exceed those of F1 car, but they both use the same principle right, so could this 'design' be used??
thanx
