I found this quote on a Thermodynamics site:
Quote:
The performance of an internal combustion engine depends on the amount of air or, more precisely, the amount of oxygen, which can be burned in one engine cycle. This amount can be expressed as a function of the density of air, which is depending on atmospherical conditions. The density specifies the mass of air, which is contained in a certain volume. Because the atmosphere is a compressible gas, pressure and temperature have a strong influence on its density. Additionally, the amount of oxygen is reduced, when the humidity is increased.
Would this confirm that a high RH would put the engine down on power? Despite the hot temp. of Malaysia, does the high RH cause the engine to ingest less oxygen, thus not burning as hot, therefore loosing power?
If so, is there a rough index of how much? Say 10hp, for every 10% increase in the RH. Of course, temp would have to be held fixed.
