Influence of vortices on underfloor aerodynamics
rccrdc
rccrdc
Re: Mclaren MP4-30 Honda
Higher res photo
Jef Patat
Jef Patat
66
I'd never have thought the airflow goes down like that at the beginning of the sidepod, I would have thought it to be more horizontal. Or is this because of the Y250? Anyone can shed a light on this?
There's low pressure behind the bargeboard, the intake has taken a slice out of the airflow that would normally go around the side, etc, etc. It's normal, that's how they try to seal the sides of the floor, hence the flickups you see around the edge of the floor for a few years, which seem counterproductive until you see the flow like this.
Jef Patat
Jef Patat
66
I guess you're talking about a flow similar to this:
henra
henra
Jef Patat wrote:I'd never have thought the airflow goes down like that at the beginning of the sidepod, I would have thought it to be more horizontal.
I'm also a bit surprised about the angle. It almost looks a bit as if it doesn't follow the undercut to the rear. Might however be just because of where they applied the flow viz. If it wouldn't follow the undercut this might be a problem because it would block off airflow to the diffuser. Would be interesting to see flow viz further downstream.
Jef Patat
Jef Patat
66
I think it might be related to what PhilipM said and the CFD I posted. Also keep in mind that flowviz visualizes the boundary flow, the flow to the rear on top of that probably is different. Carefully check these images:
http://www.f1technical.net/forum/viewto ... 37#p386737
By all means, take my opinion as an educated guess and nothing more.
bhall II
bhall II
477
Teams have been making use of the Coanda effect for years. The development of Coanda exhausts just made them better at it.
Jef Patat
Jef Patat
66
What I'm trying to say was I expected something like the red line (deliberately red because I'm wrong) and instead we see something like the green line. It is as if that flow is pushed off the edge of the floor, there must be a reason for that. I would have expected they'd like that flow to go to the rear.
I find this aero area mighty interesting but I my understanding of it is less than 0.000001%.
@diffuser:
I know about it, I find it interesting and I don't want to explain it because I will be telling you nonsense. I'm not the correct person to add anything more to it than this.
https://tianyizf1.wordpress.com/tag/y250-vortex/
bhall II
bhall II
477
Jef Patat wrote:It is as if that flow is pushed off the edge of the floor, there must be a reason for that. I would have expected they'd like that flow to go to the rear.
All air flow between the front wheels is directed to that area in order to generate sealing vortices along the flanks of the floor. You can sorta see Caterham's version of it below (car's right, viewer's left).
To keep that air flow as strong as possible, teams don't redirect it any more than is absolutely necessary. That's why the bottom of the sidepod turning vane is positioned with roughly the same angle as the barge board.
Think of the flip-up (highlighted) as something like a little diffuser that tries to pull this air flow as far outboard as possible, because you want to seal as much of the floor as possible.
Any air flow that makes it to the rear of the car from this point is a bonus. The rest is either rolled up into that vortex, cast off and away, or completely screws up everything...
They are trying to bring the centre of pressure forward I suspect.
Abarth
45
Shouldn't the g"green" flow remain more attached to the sidepod instead of leaving it on the sides, which can be seen on the floor?
Jef Patat
Jef Patat
66
Abarth wrote:Shouldn't the g"green" flow remain more attached to the sidepod instead of leaving it on the sides, which can be seen on the floor?
You should read the post of bhall II above before asking the same question again :wink:
Abarth
45
I apologize. Somehow thought that your question was more about the inclination of the flow, but not to the fact that it leaves that region completely....
Now rereading it makes some sense, althought to me it looks like its leaving in a too big angle to remain a sealing help for the floor.
McMrocks
McMrocks
32
What we see in the caterham video is the vortex generated from the barge boards
from chuckdanny found in that thread: http://www.f1technical.net/forum/viewto ... 3&start=60
bhall II
bhall II
477
McMrocks wrote:What we see in the caterham video is the vortex generated from the barge boards
As opposed to...?
If I've implied a different interaction, it's purely unintentional.
