Re: Mercedes Power Unit Hardware & Software
MtthsMlw wrote:
Tue Nov 19, 2019 9:05 pm
godlameroso wrote:
Tue Nov 19, 2019 8:44 pm
Just_a_fan wrote:
Tue Nov 19, 2019 5:43 pm
That's the point, isn't it? The ability to run the PU at maximum output for longer is going to give a real benefit in race pace. If your engine only has to do 1 or 2 races compared to one that has already done 6 races, you're at a distinct advantage of being able to run the PU harder than the other guy.
That is true. Is there any word on Bottas needing a new ICE?
No decision before next week. The engine burned or lost excessive amounts of oil and shut down precautionary as the tank was empty.
They could use an older one but that isn't preferred.
Typically such severe oil burning comes from a failed turbo seal. I doubt they damaged the rings or something silly like that.
godlameroso wrote:
Tue Nov 19, 2019 9:43 pm
It definitely sprayed some clearish liquid, you can see that on the onboard of the following Renault.
Nonserviam85
Nonserviam85
Just_a_fan wrote:
Mon Nov 18, 2019 6:50 pm
PlatinumZealot wrote:
Mon Nov 18, 2019 5:04 pm
The power target is still the same for relevant modes. An engine to be used in its last race will have the same output target as that in its first race. This is why the teams manage the power modes to ensure that they have reliable output.
If the power is the same for all modes, why have the modes? Why does "party mode" give greater performance if the power is the same?
The reality is that the engines are run at a level that gives them reliability for the required number of races. If they could make the things do 7 races in "party mode" they surely would do so. They don't so they have to limit the performance used by the drivers.The available performance is determined broadly in the engine's design but is specific to each engine and its particular use history. That's why the drivers are limited to what modes they can use.
Typically for electrical and mechanical assets you can have the same lifetime allowing some stressing under predefined limits. Typical examples are Transformers when you can allow 150% output for an hour and 300% for 1 min without reducing the life, I believe the PU manufacturers have something similar in place.
Juzh
160
Just_a_fan wrote:
Mon Nov 18, 2019 10:33 am
Bill wrote:
Mon Nov 18, 2019 9:46 am
Lewis had a Mercedes car a championship winning machine and very fresh tires and couldn't pass Gasly. In Austria when they lost in high altitude they blamed the temperatures not the pu .
Lewis has used 3 engines for the season, Gasly has used 7. The unit in Gasly's car was fresher and he was using everything it had - he said in the cool down room that he was holding the overtake button the whole way.
Strat 5 activated "overtake" mode automatically on the main straight in brazil. You can hear wastegates open when he's on full throttle exiting the final corner, which is a dead giveaway. So let's not pretend hamilton was just cruising up the hill.
Strat 5 is also an unsustainable mode, it deploys more energy than it can recover. When Bottas was chasing down Leclerc he was juggling strat switch constantly in and out of strat 5, then got told at some point to stop doing that because even with management the battery was getting too low.
As for the engine mileage, it's true gasly has used tons more engines but actual mileage of used PUs is unknown.
63l8qrrfy6
63l8qrrfy6
368
Quick update after yet another drinking session with a mate who works in brixworth - bottas' engine is confirmed fubar (source of the oil leak was a big hole in the block) - he'll either use his second engine or take a penalty and put in another spec 3 PU for the last race.
Will post jucy Ferrari stories once I've recovered from what's shaping up to be a brutal hangover.
Mudflap wrote:
Thu Nov 21, 2019 1:13 am
How does one get a hole in an engine block? Without the pistons going crazy.
Hope you recover quickly :wink:
Wass85
Wass85
Ask them if there's any jobs going, I'm not very clever but I can lift heavy stuff.....
Big Tea
98
MtthsMlw wrote:
Thu Nov 21, 2019 8:43 am
The last hole I had in a block without affecting piston/rods/crank was a generator mount failed and pulled a chunk outwards. It was above the internal oil level but clouds of vapour came out.
(Clarify) I mean from outer wall of block to outside world rather than into 'workings' area.
ENGINE TUNER
ENGINE TUNER
25
Tis but a scratch, I bet a glob of jb weld could fix it right up.
ENGINE TUNER
ENGINE TUNER
25
Juzh wrote:
Wed Nov 20, 2019 4:21 pm
"Strat 5" for Merc in Brazil may not be the same as "strat 5" for Merc in COTA. They most probably pegged the engine back for reliability reasons because of the difference in cooling potential.
Even if strat 5 is "max power" in both cota and Brazil, "max power" is not at the same level at both places, for 2 reasons, 1) the altitude(oxygen level) and 2) they probably ran the engine safer because of the lower cooling potential and because it is older.
Juzh
160
ENGINE TUNER wrote:
Thu Nov 21, 2019 7:22 pm
"Strat 5" for Merc in Brazil may not be the same as "strat 5" for Merc in COTA. Hey most probably pegged the engine back for reliability reasons because of the difference in cooling potential.
How is this different from other manufacturers? Do they not compete at the same altitude as mercedes somehow?
ENGINE TUNER
ENGINE TUNER
25
Juzh wrote:
Thu Nov 21, 2019 10:16 pm
As we saw in Austria, Merc has chosen a large enough compromise on their cooling for this year that the altitude seems to effect them more than the others. I think it has something to do with their radiator air inlets and how they are lower than everyone else's, possibly. Everyone else has moved away from that style sidepod opening style, don't know why Merc haven't.
563
Stating the obvious here but thinner air at altitude does not accept heat as effectively so any team (MB) that has designed their cooling system (including intercooler) to be marginal, may be power limited by their cooling system at high altitude tracks.
zibby43
zibby43
612
That is the cliffhanger to end all cliffhangers man! You've always been spot-on with your info. Cannot wait to read further. Hope that hangover clears up quickly lol.
zibby43
zibby43
612
ENGINE TUNER wrote:
Fri Nov 22, 2019 12:59 am
Merc already publicly admitted that they made an error in calculating how much cooling they'd need in the design phase of the car. By the time they had noticed the error, it would've required architecture changes that were too substantial to recover from.
I don't anticipate Merc adopting the high-top inlets for 2020.
