F1 Camera Streaming Technology
AdvancedF1
AdvancedF1
Hi guys
I've got a project whereby I need to mount cameras on A1 racecars and to be honest struggling quite a bit in getting the information to have this implemented.
First off, does anyone know a company that supply and have the necessary knowledge and expertise for this type of implementation?
Secondly, to describe the current scenario - I need to mount two cameras on the racecar whereby it needs to transmit the video footage and telemetry wirelessly to a receiver of some sort. I would assume that sector radios to be installed across the track so the internal transmitter within the car can send the data / footage to them, and from there to the end point devices to have it viewed on demand and live. Other factors I'm concerned about are the following:
* Cameras - Analog or IP?
* DVR or switch to be installed in the racecar? Also, the option chosen needs to have the correct power output so it can be powered by the car.
* What type of transmitter / radio to be used to send out the data.
Any advice / suggestions as to how and what type of technology to be used would be greatly appreciated.
Regards
tinhouse
tinhouse
Re: F1 Camera Streaming Technology
AdvancedF1 wrote:Hi guys
Regards
Extreme Facilities do this kind of stuff: http://www.extremefacilities.com/
They do hire or sales depending what you need.
<Caveat: I've worked with them on other types of filming but not car-mounted so I can't recommend them for that from personal experience, but they have a great reputation for it.>
strad
117
Go-Pro is the go to camera of choice. With all kinds of mounts they are what guys like Ken Block use as well as many of the exhibitions runs by F1 teams.
Sir Stirling Moss
Andres125sx
About video transmision..... HD?
Then Amimon Connex, or even Connex Mini (new, not released yet) is your best choice.
There are more digital video trasnmitters wich support 1080 60p, but not without lag at an affordable price. It also provides a serial link wich could be used for telemetry
About latency, this vtx have zero latency, but the camera itself will have some, and the display you use to watch the image will probably have some too
About cameras, gopro is great for the size, but there are much smaller cameras if you need it.
BTW, I have no relation with Amimon, but I have a drone I use for aerial filming, and Connex is one of the first items on my wish list.
Cold Fussion
Cold Fussion
93
If you go with something like a gopro then you will need a good vibration damping mount otherwise your image will be a jello mess.
