firasf1dream wrote:turbof1 wrote:If you are looking at a front wing from the front:
https://u.cubeupload.com/turbof1/MW.jpg
(without endplate and cascade to simplify), you'll notice the upperflap has an outboard section (2 elements) and an inboard section (1 element). The outboard section is static: these are solid pieces fixed to the footplate and sometimes the endplate.
The inboard upperflap (in this case: some teams can adjust 2 inboard flaps) can be adjusted through a screw mechanism. Mercedes has a somewhat different system, where the uppermost flap is fixed toward the flap below, but not towards the rest of the wing:
The supports are quite complex. If the screw mechanism is used, the supports can turn and pivot the flaps, but otherwise they are fixed. These are quite complex set ups, with a lot of work inside the flaps. Yellow is the divider between inboard and outboard sections, blue is the screw itself, and green acts as both a support for rigidity and as pivotting system.
thank you turbof1, so as you say the pivot is at the bottom of the green support ? so if that metal shape at the green of the support is taken away i would see it has like a pin screw with a little thread at it's tip which will go in the green support from the side of the endplate and towards the center line of the car and will enter the metal piece but at it's middle there is no thread which will make it rotate inside of the screen support ?
is this how it pivots somehow ?
http://i96.photobucket.com/albums/l196/ ... 4qwgjy.jpg
I really do not have knowledge on specific inner workings of it. Especially not given as you see that Ferrari uses a somewhat different system. However, your proposal is viable.
and how many degrees can this flap be adjusted ? and when adjusted wouldn't that make disturbance in the flow at the metal wall between the flap and the outer part fixed to the footplate ?
I'm making rough guesses here, but assuming full angle is 90° at the trailling edge, you could go -again, I think- to around 110-120°, so 30° leeway on a guess. Note you'll probably never see such drastic changes in the race: the flap will have a set angle at the start of the race and will be adjusted to keep balance. You might see around 10° variance during the race, also depending on the amount of pitstops.
If a circuit requires inherently even less angle of attack, teams are going to change the flaps themselves to have simply have less surface area. Do note that the inner most part of the flaps at the Y250 region are very, very important. Teams very much refrain from tampering with it, resulting in some weird flaps:
The the flap tips in general in that region will also barely change position. Infact they'll probably stay in place:
I do not believe you'll get issues at the metal wall. Infact it will always create a vortex there even if there's no gap between outer and innder part. Teams put flap adjuster and metal wall in a very specific region to help divert airflow around the tyre.
