I hope you are well
i would like please some explanation about the suspension setup change like camber and others and some default parameters. I will be referring to this picture below
1 - As we can see in the picture it says shims, so i would like to know are these shims for camber change or for Kingpin change ?
2 - for camber change, as we know that we must change the wishbones length for that ( i remember last year I asked a technician in redbull show how does he change the camber, he showed me the shims and said we add shims to where it says shims in the picture above, so i wonder if we add shims that will change the kingpin angle !
3 - when they design the upright, i saw that usually the above wishbone link comes in 2 pieces in which you can insert shims as we can see in the picture and for the bottom wishbone the connection point on the upright is built in and cannot change !
4 - we can see in the picture that the black piece for the upper wishbone connection and the upright arm has an angle with the wheel vertical center line , so i believe that is in the same line as the upper wishbone right ?
thank you in advance
