dans79 wrote:I fail to see how this is going to offer any kind of advantage., am i missing something?
If it was me, I'd be trying to come up with some way to take advantage of the bodies natural mechanics to yield a non linear response.
What do you mean, specifically?
My interpretation is that these paddles with divots in them may allow the driver to both push & pull upon the lever, as well as provide a hard point, a hard stop, for the fingertips to rest against. This could provide stability to improve fine, subtle movement.
Some analogies:
-when operating radio or HVAC controls while driving, I sometimes brace my hand or free fingers against the peripheral surfaces for stability
-twisting a motorcycle throttle for me is easier, more controllable, when I have one or two fingers resting upon the brake lever
-when drawing it is difficult to produce small exact motion without bracing the hand in some way
I'm sure there are many more examples, but I'm drawing a blank. I would like to hear if anyone has some, actually!
In this steering wheel example, there would be a bridging, bracing act spanning the hand grip to the divots. The greater, primary force is exerted there, making the hand & fingers rigid for stability. Feeding in fine lever control then becomes the secondary, finer motion.
Also, since these are depressions, the finger is locked into place preventing up-down, fore-aft slippage. Perhaps a good idea consider starting line accelerations & oscillations. Anything that makes operating the paddle more predictable would be of benefit.
