2017 LMP1 front fenders
dujedcv
dujedcv
Can someone please explain the exact reason and the purpose of the enlarged frontal area of the front fenders on the 2017 Porsche 919 and the Audi R18?
As seen on the newly-surfaced photo of the stillborn 2017 Audi R18:
https://pbs.twimg.com/media/DBQdp3YXYAAkk6o.jpg
And the 2017 Porsche 919:
https://storage.googleapis.com/gtspirit ... brid-6.jpg
And for comparison, the 2016 919:
http://www.car-revs-daily.com/wp-conten ... rid-31.jpg
A comparison between the 2017 Porsche 919 and Toyota TS050:
https://pbs.twimg.com/media/C8MPuBIUAAAeePE.jpg:large
Re: 2017 LMP1 front fenders
If the regulations don't mandate it, then I suppose bigger fenders means less space for the front wing, but also gives you more air flow control over the unsprung part of the car.
I saw this post on Reddit, I'll drop my comments here;
A more efficient trailing edge is my best guess. With a wider front it can start the outward shape sooner, leaving more unobstructed space for the diffuser. This would be useful this year because the legality panels aren't mandatory anymore, which were an obstruction previously
Pre-2017 rules required bodywork in this area so manufacturers put panels in this area. These pose an obstruction for the exit flow. 2017 rules dont have this requirement anymore, thus airflow out of the diffuser is unobstructed.
So I think it is so they can bring the trailing edge of the fender further forward, maximizing exit area for the diffuser. This seems to be the goal on the 919 as they also have brought the sidepods as far back as possible
roon
roon
412
The starting point of the trailing edge taper is still dictated by the width of the tire + the internal fender gap needed to accomodate steering angle. I think these pontoon fenders may have more to do with either yaw stability or lift reduction.
rjsa
rjsa
51
I have been trying this on my MVRC challenge car and to be honest didn't see much difference. Now that's just trying to reduce bonnet/fender lift, and it did alleviate the low pressure hotspot downstream, but nothing really worth writing home about on the numbers.
I don't know what else it messes with downstream on the Porsche. And without the whole setup is really hard to say exactly where it matters.
roon
roon
412
It seems like it would divert relatively more air around than the sides, and less over the top i.e. less potential for a low pressure over the top of the fender. The roundedness may help keep flow attached around the sides of the fenders through a variety of yaw angles and thus provide more consistent flow over the top of the front wing/diffuser and around the sides of the car.
The low downforce Toyota is a bit more Porsche like.
Compared to
If you look at what Porsche was doing last year.
High downforce
Low Downforce
It seems like those boxy fenders reduce drag somehow.
outsid3r
Sevach wrote:
04 Jun 2017, 18:25
I think the reason behind it is simple(-ish) really... Boxy fenders separate most of the airflow horizontally (as if you have a vertical fin) while a ramp-like fenders separate airflow both horizontally and even more so vertically, creating more downforce (and more drag)
Edit: Please note that I don't even consider myself at a novice level when it comes to aerodynamics, so bear with me if my reasoning doesn't make sense at all :)
rjsa
rjsa
51
Sevach wrote:
04 Jun 2017, 18:25
https://cdn-5.motorsport.com/images/mgl ... in-yuj.jpg
Compared to
https://cdn-5.motorsport.com/images/mgl ... ui-kob.jpg
High downforce
Low Downforce
http://www.infomotor.com.br/site/wp-con ... 80x800.jpg
What I see on both size is a 50~100mm difference on the bonnets trailing edge, what means that's how deeper the front diffusers are.
Now if you look at the 2017 & 2016 Porsche:
You'll see they got rid of the very pronounced venturi formed between the nose and fenders.
outsid3r wrote:
05 Jun 2017, 12:06
Sevach wrote:
04 Jun 2017, 18:25
I agree, the low downforce versions seem to direct air towards the flank of the car while the high downforce seems more minimalistic with air going inside and over it.
rjsa wrote:
05 Jun 2017, 12:35
Sevach wrote:
04 Jun 2017, 18:25
Compared to
High downforce
Low Downforce
So improved front diffuser efficiency while also reducing drag? That's what i'm getting.
Porsche fenders got a lot smaller, and rounder, after Le Mans.
Cold Fussion
Cold Fussion
93
That's a pretty radical change.
johnny comelately
johnny comelately
110
Great to find this subject as when the Porsche 919 first came out (2014/15) it looked like blunt force trauma to the victim air and after reading the posts i'm still not sure, could the lighting apparatus needs be some of the answer?
sandrosm
sandrosm
johnny comelately wrote:
24 Feb 2018, 08:33
https://upload.wikimedia.org/wikipedia/ ... rid_20.jpg
The upright fenders have the main function of diverging the air to side instead of going over the top of the mandated big extracting holes over the wheels creating more downforce although with a poor lift to drag ratio. It's generally a less draggy solution and it actually makes sense. To understand what I'm saying, here is a photo of an early 2014 Dome S103 windtunnel prototype model that took this concept to the extreme.
In the final version it was not as pronounced, though:
(It was not very successful but it looked amazing =P~ )
