CFD: Simulating Mercedes W08 super-ted cape nose
Anyway, back to W08... As I said, I'm working on figuring out super-ted-cape thing, so this is my preliminary model for CFD. Very crude concerning front wing, but my effort went around the nose area. As for FW, suspension and tyres, probably even a basic shape for the rest of the car, it will come later. For this first iteration, I'll use a crude but efficient CFD tool, and for final one I'll use the best I can at the moment (if I'll be allowed to)... What do you guys think about the accuracy of the nose area and the cape thing? Any suggestion is more than welcome. :)
ema00
ema00
Re: Mercedes AMG F1 W08 EQ Power +
the front "diffusor" is very similar to the real one, congratulations...
I see de s-duct on the top but can't see the holes on the bottom, have you put them in the model? If so I think ther's another hole just at the beginning of the nose... you can see it here
finally, which program have you used to build this model?
ema00 wrote:
01 Jun 2017, 22:34
http://www.newsf1.it/wp-content/uploads ... 0014-1.jpg
Thanks! Ducting on the bottom is visible on the last screenshot I posted, based on this picture here:
CAD model is made in Catia V5. The hole on the front of the nose is verly likely for driver cooling and therefore uninteresting at this point. :)
everythingisawesome
everythingisawesome
Vanja #66 wrote:
01 Jun 2017, 21:56
https://image.ibb.co/d0gR5v/1.jpg
https://image.ibb.co/cGhYkv/2.jpg
https://image.ibb.co/dwqxCa/3.jpg
https://image.ibb.co/keccCa/4.jpg
https://image.ibb.co/nETTJF/5.jpg
Nice work! It's especially difficult with Catia!
roon
roon
412
everythingisawesome wrote:
02 Jun 2017, 09:30
Isn't it what the teams would be using?
As far as I know, both Mercedes, Red Bull and Ferrari use both Catia and Siemens NX for their various CAD models. Not sure about Creo, even though it's what Dallara uses... Surfacing is really, really good in Catia, and that's important for aero package design...
I should be able to post first CFD results in the next 2-3 hours...
Here they are...
What you can see on these pictures is that there is a vortex on the edge of the cape, as expected. What I also expected is another vortex inside the cape, but there isn't one. There could be many reasons for this, bad CFD set-up is most likely. And yeah, for this first set-up I forgot to include rake angle and generally front wing closer to the ground - corrected version is being calculated as we speak.
As for the vortex occurring here where the tub begins (after the nose expansion near the tub), it's a strange one, not sure what to think of it.
Pressure plot here, as you can see Y250 vortex is really strong. I'm working on geometry much closer to reality (at least I hope so), so there's a lot more to come for front wing. Separation on cape leading edge and wing flap's trailing edge is bad geometry on my side, partly due to non-existent rake angle.
There's also some turbulence (swirling) inside the S-duct, though this is far from what S-duct once was. :) Naturally, this is also bad geometry...
From this isolated model for CFD I couldn't learn much. Cape, at least in this first simulation, isn't behaving like diffuser as there isn't a vortex forming under the "ramp". I'm not sure if this is even supposed to happen, as this entire geometry is quite smooth and ramp doesn't have any sudden and acute changes in geometry (like typical diffuser does, which is what triggers it's vortices) and this is visible on the pictures of the car. There is an increase in pressure on the top side of the ramp, as is expected in free stream...
Feel free to interpret these preliminary results as wildly as possible, fresh ideas are scarce these days. :)
timbo
timbo
113
It would be interesting to compare results of the nosecone with and without that blade. Also, can you try how it works in yaw?
Webber2011
Webber2011
Vanja #66 wrote:
02 Jun 2017, 21:36
Here they are...
https://image.ibb.co/dS3eQv/W1.jpg
https://image.ibb.co/n5Zm5v/W2.jpg
https://image.ibb.co/cgL4sa/W3.jpg
https://image.ibb.co/jYn65v/W4.jpg
https://image.ibb.co/maH65v/W5.jpg
https://image.ibb.co/imJDkv/P1.jpg
https://image.ibb.co/eRSTJF/P2.jpg
https://image.ibb.co/iZ9ayF/P3.jpg
https://image.ibb.co/mZwcCa/P4.jpg
I'm afraid I'm not qualified to interpret your results mate, but I do applaud your effort ! ! !
I have a basic understanding of Aero, and posts like yours are the exact reason I signed up to this Forum.
You're showing me in visual terms and simple language what's going on.
I'm sure someone else will add to the conversation shortly with a bunch of X x Y/(X + W) x 3.1415 x(z/w) stuff that I have no chance of following :lol: :lol: :lol:
But I'd just like to say thanks for your work, these type of posts are the reason I really enjoy visiting F1Technical.
Cheers,
Simon
timbo wrote:
03 Jun 2017, 00:25
In these isolated conditions, it definitely adds some downforce with very small drag penalty, so it's beneficial. It would be no problem to check how's the situation without it. As for yaw, It will take more time to get the results (twice as large domain namely), but no problem... However, I'm not sure if it will be accurate, it may be able to give us just a rough estimate of flow structures.
Here are results with some rake angle and FW closer to the ground. Not much difference overall, but Y250 and cape vortices seem to be stronger...
Cheers Simon, I'm glad you enjoyed! :)
henra
henra
Vanja #66 wrote:
02 Jun 2017, 21:36
Thanks a lot for this great effort!
Initially I thought I had an idea what the cape was meant to achieve (mainly accelerating and directing Y250 with the rest of the 'cape' stabilizing airflow in the middle section towards the Tray) but your CFD doesn't seem to show this being the case. So I'm back to square one after having seen your CFD.
But even challenging/destroying an (apparently wrong) assumption is of benefit. So: Thanks for that!
Now I'm waiting for other to come up with a more correct assumption of this interesting device.
jose_lb
jose_lb
I'd say bring the wheels in before going for yaw.
And align the LE of the cape with the streamlines over the nose.
Maybe your mesh is too coarse to capture those vortices. Try plotting the streamwise component of vorticity in different planes.
I'm working on more accurate model for FW, then I'll add tyres and suspension arms. After that, I'll be doing the sim again, probably 3 times - half-model with cape, without cape and then full model in yaw. I can't say what comes after that and if I'll be able to to a full car sim. Even if I do, I'm not sure how useful it'll be as it will be far from the real thing...
CBeck113
CBeck113
51
Please simulate the car in a curve once you've finished all the straight line work - I still believe that this is to protect, and from your sims so far, even strengthen the y250 in corners, more so than on straights.
Those sims are missing a few key elements... So when that is complete you can try other thing.
