Bearings and drag reduction
Airtek 162
Airtek 162
Hello
I've been looking for a answer for my question on the net and can't find one regarding bearings. What type do f1 cars use in there front hubs to reduce friction? Road cars use tapered roller bearings which aren't very low friction so I guess they use ceramic hybrid bearings or something similar low friction bearing but are they tapered or some other form of bearing. And do they get coated in anything else to be even more friction free, run in oil instead or grease or any other trick ideas to help them spin easier.
Just something I've been thinking about.
Cheers
670
Re: Bearings and drag reduction
someone who recognises that there's mechanical drag as well as aerodynamic drag !
my guess is that the mechanical drag from the tyres is 2 orders of magnitude greater than that from the wheel bearings
night infra-red footage from police helicopters shows cars being pursued heat the road with their tyres
MrPotatoHead
Fairly standard angular contact ceramic bearings.
As Tommy states the friction caused by the tires themselves is much greater than any minute friction in a set of roller bearings.
If you ever get to push an F1 car (or any modern single seater) you'll be amazed at how much effort it takes to roll them around though.
bill shoe
bill shoe
151
Bearing friction does matter, but the more important considerations for Formula 1 wheel bearings are their size/weight vs. the installation stiffness (camber, toe).
Strength and life are also important.
Remember too that the lubricant in the bearing make a big difference. F1 can use light greases because they change the parts much more than you do your typical road car. The f1 car has extremley low bearing friction i would guess.
riff_raff
riff_raff
bill shoe wrote:
01 Aug 2017, 01:06
A set of properly sized and pre-loaded, back-to-back angular contact bearings would give best efficiency. Using ceramic (silicon nitride) races and balls would minimize weight/inertia and maximize stiffness. But would also cost a fortune.
A: Start with a large one!"
579
Oil bath lubrication might further reduce friction.
MrPotatoHead
One of the biggest things they have to manage with the wheel bearings / uprights / hub assemblies is heat.
That is the number one enemy to fight.
hardingfv32
hardingfv32
gruntguru wrote:
02 Aug 2017, 07:34
I am not sure that oil bath would reduce drag. Oil bath was not in use a decade ago from the parts I have seen.
I would say a lubricating mist is best for drag reduction but I do not see how that gets done in a hub.
A grease NLGI Number (relative hardness) has nothing to to with its viscosity number. A thick looking grease can have a very low viscosity at the point where the bearing elements are in contact. I would say using the proper amount of grease (packing?) that the lubrication drag is very similar to a liquid lubricant.
Preparation/setup of wheel bearings is a very precise science. Timken offers a service to NASCAR teams that packs and sets the prelaod of their front hubs. Interesting that it is considered beyond the skill set of the teams.
Brian
Greg Locock
Greg Locock
239
The main difficulty with wheel bearings is that the rotor and anything it is attached to heats up a lot due to braking, and so it expands. The strut side of things doesn't heat up as much. This means all your carefully worked out preload suddenly changes (which way depends on whether you are running stub axles or live axles). The preload in the bearings is optimised around life, toe and camber stiffness, and rolling resistance.
This is one of the reasons why many production cars now use hub units, in which the bearings are provided as a pair in a housing, all you have to do is press the housing into place. No more bearing setting.
Zynerji
112
Are there any rules specifically preventing mag lev bearings in the hubs?
It wouldn't be difficult to apply torque from the bearing itself...
Greg Locock wrote:
04 Aug 2017, 23:40
I've seen plenty of ruined wheel bearings and hubs from axle nuts not being tight enough in those pressed in two piece wheel bearings.
bill shoe
bill shoe
151
godlameroso wrote:
05 Aug 2017, 01:12
From the factory, or after the bearings have been changed in the field at least once?
I'm always surprised at how high the torque spec is when I put axle nuts on, your comment will make me pay attention and do it right!
Greg Locock
Greg Locock
239
Be careful, are you sure you are talking about hub units?
These things
http://www.skf.com/binary/30-147232/457284.pdf
As you can see, tightening the axle nut merely compresses the female spline, it does nothing much to the bearing preload.
bill shoe wrote:
05 Aug 2017, 02:47
godlameroso wrote:
05 Aug 2017, 01:12
From the factory, they're just not torqued down enough, at least in this case. Spec is 180ft lbs and was later updated to 220ft I do at least 300, and put a light coat of oil on the face of the nut to get proper tension as torque does not always equal tension, especially if there's any rust on the hub. Since they're always staked, or cotter'ed or some other fail safe for the nut backing out it's not a big deal.
