Mexico affects on tyres
marmer
marmer
With the high altitude at the track how does this affect the tyres.
Obviously pressure is pressure as in its reletive to the outside but the amount of air inside the tyre will be less to achieve the same level of pressure.
Never heard it mentioned but does this affect things like structural integrity of the tyre and how the tyre heats up
Jersey Tom
Jersey Tom
167
Re: Mexico affects on tyres
No structural effect. I suppose maybe there could be some slight change in convective cooling to the air.
marmer wrote: ↑
29 Oct 2017, 12:44
it doesn't.
negliable
no.
pressure, fricture and temperature affect the tire. the only effect mexico has compared to for example canada in a rainy day is that it's hotter. but malaysia is far hotter, so there really is no issue there.
so the high altitude and 'slightly' thinner atmosphere does not affect the tyres.
indirectly, thinner atmosphere has a slight effect on brake temperatures due to cooling effeciency and that has a secondary effect on the tires due to the heat dissipation affecting the wheel and thus tires since those are immediately in the vincinity of the brakes, but nothing that is not controllable or is not anticipated. For example, Malaysia's heat has a far more and direct influence on the tires whereas Mexico's altitude does not have a direct influence at all.
The air is of lower density so tyre cooling will be affected. Also.. The absolute pressures in the tyres will be different to sea level. The gauge pressures should remain the same though.
Solar heating will also be greater in relation yo convective cooling. So the tyre is more sensitive to air temperature swings.
