Suzuki Hayabusa Inline Five
Rage
Rage
I think this is a very cool project :)
https://www.engineswapdepot.com/?p=20296
humble sabot
27
Re: Suzuki Hayabusa Inline Five
I'm trying to understand the justification for ever building a 5 cylinder at all. But It's an interesting choice.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
Facts Only
Facts Only
188
People have literally run out of things to do with Hay abusa engines by the looks of it. Turbocharged, Supercharged, Big Bore, Long Stroke, billet block for hewland gearbox, V8 version all been done so now it's this. Seems a tad pointless but I bet it will sound mental.
roon
roon
412
Opinions Only wrote:
26 Jan 2018, 12:51
Single, twin, triple, I6, V16, flat-8, and coffee-table variants still have yet to see the light of day.
RicME85
52
humble sabot wrote:
26 Jan 2018, 06:06
Isnt it hat they are just trying to squeeze an extra cylinder into an existing frame rather than plucking 5 cylinder out of the air as an idea for a project
humble sabot
27
Why one then? Why not two and end up with a straight six? They're inherently smoother.
People have been making V8s from motorcycle engines for a few years now.
static balance
dynamic balance
static imbalance
dynamic imbalance
RicME85
52
because that is all the space they have got in the existing frame
Maritimer
Maritimer
19
Nevermind this, passive aggressive negative voters can kiss my butt :lol:
humble sabot
27
I've never heard that.
static balance
dynamic balance
static imbalance
dynamic imbalance
Benard Bonhomme
Benard Bonhomme
Maritimer wrote:
29 Jan 2018, 15:33
Inline 5 have the best natural balance iirc, even better than 6s
It is not about the balance, but the irregularity of the engine. Generally, engines with an uneven number of cylinders have an irregularity way better than engines with an even number of cylinders:
https://www.gtisoft.com/wp-content/uplo ... ITE_GM.pdf
sosic2121
sosic2121
Maritimer wrote:
29 Jan 2018, 15:33
I don't think that's true. Inline 5 requires balancing shaft.
Maritimer
Maritimer
19
sosic2121 wrote:
29 Jan 2018, 19:24
Maritimer wrote:
29 Jan 2018, 15:33
Good enough then, lower internal friction might be what im thinking of
Greg Locock
Greg Locock
239
True boxers, I6 and v12 (which is basically two I6s) have the best natural secondary balance . A balancer shaft works at one harmonic only (typically twice crankshaft speed aka second order) , but the piston on crank assembly generates a whole series of forces, not just second order.
i5s and v10s aren't horrible, but they aren't anything like as smooth as an I6 unless they have a balancer shaft. I3s and 90 degree V6s and your usual I4 all create lots of powerful inertial forces.
Roughly speaking an I4 vibrates at 20 g rms at the redline at WOT, an I6 is at 5g rms. 10-1000 Hz.
The disadvantage of I6s and so on is that the crankshaft is so long that you run into torsional and bending problems with the crank.
Friction wise, the fewer cylinders the better for a given capacity , and a balancer shaft also adds friction.
670
a Mr Duckworth said DFV valve motion produced bigger forces than those normally regarded as the causes of vibration
63l8qrrfy6
63l8qrrfy6
368
Tommy Cookers wrote:
29 Jan 2018, 22:55
Mostly because his 'constant acceleration cams' were particularly bad.
DFV cams were pretty out of date even for that time - the acceleration profile consisting of 3 'constant acceleration' plateaus resulted in infinite jerk at each transition.
His compliant idler was a clever band aid but spring failures were never really cured.
