New helmet design for 2019
The FIA unveiled a new helmet design today, to be mandated for the 2019 season:
https://www.fia.com/news/fia-reveals-ul ... -helmet-f1
digitalrurouni
digitalrurouni
Re: New helmet design for 2019
I never realized helmets were released with such pomp and circumstance!!
JonoNic
turbof1 wrote:The FIA unveiled a new helmet design today, to be mandated for the 2019 season:
Thanks for the links
I just pulled this from the article
Toughened Tests
Under the new FIA 8860-2018 standard all helmets must withstand the following tests:
Standard impact: Helmet impact at 9.5m/s. Peak deceleration on ‘driver’s head’ shall not exceed 275G.
Low velocity impact: Helmet impact at 6m/s. Peak deceleration shall not exceed 200G with a maximum average of 180g.
Low lateral impact: Helmet impact at 8.5m/s. Peak deceleration shall not exceed 275G.
Advanced Ballistic Protection: A 225g metal projectile fired at 250km/h. The peak deceleration shall not exceed 275G.
Crush: A 10kg weight falling 5.1 metres onto helmet. Lateral and longitudinal tests. The transmitted force should not exceed 10 kN.
Shell penetration: A 4kg impactor dropped onto helmet at 7.7 m/s.
Visor penetration: Air rifle fires 1.2g pellet at visor. Pellet must not penetrate the interior of the helmet.
Visor coating: Transmitter test to ensure colouration and vision is not significantly changed or distorted.
Retention system: Roll-off test and dynamic test to ensure strength of chin strap and its attachments.
Chin guard linear impact: Impact test with full headform at 5.5m/s. The peak deceleration shall not exceed 275G.
Chin guard crush: Hammer hits chin guard and measures ability to keep impact away from the head.
FHR mechanical strength: Test to ensure high strength of attachment points for Frontal Head Restraints.
Projection and surface friction: Test to ensure helmet surface uniformity and that friction is minimised. Shell surface also subjected to BARCOL hardness test for resistance to penetration.
Flammability: Helmet exposed to 790 C° flame; it must self-extinguish once flame is removed.
Always find the gap then use it.
GTO99
Why does it look like it is made of Lego?
I'm curious how it will look painted, but it's safety steps seem solid.
Peter1919
Peter1919
Is it just me or does that visor look quite narrow?
Big Tea
99
Peter1919 wrote:
06 Jun 2018, 22:59
Probably same apparent view as through the HALO
DiogoBrand
74
Why did they remove the upper visor frame? (The one they added after Massa's accident)
Jolle
Jolle
133
DiogoBrand wrote:
06 Jun 2018, 23:30
Guess it’s integrated now. The zylon strip is partly on top or a part of the visor they block off anyway against the sun. Now it’s just carbon/Kevlar/Zylon/unutanium with foam between the Forehead and the shell
Maritimer
Maritimer
19
Peter1919 wrote:
06 Jun 2018, 22:59
I think if you account for the ballistic strip they have now it's more or less the same. They closed the opening 1cm so it's not a huge change either way.
J.A.W.
J.A.W.
109
& suddenly.. its the future-past!
& to replace the hideous halo..
J.A.W.
J.A.W.
109
& its.. Max Verstappen's new.. "Yeah, I'm racing in dick-head mode" - helmet..
DiogoBrand
74
J.A.W. wrote:
07 Jun 2018, 01:00
https://www.bikehugger.com/images/blog/twiggy_robot.jpg
I heard the manufacturer for his helmet will be Bell...
end.
johnny vee
The FIA has revealed a new helmet standard that will be mandatory in Formula 1 from the 2019 season
https://www.motorsport.com/f1/news/fia- ... 1-1044851/
The top of the helmet's visor opening has been lowered by 10mm to incorporate advanced ballistic protection that "achieves unprecedented levels of safety during impact from debris," according to a FIA statement.
Standard impact: Helmet impact at 9.5m/s. Peak deceleration on 'driver's head' shall not exceed 275G.
"Because you didn't come here to make the choice, you've already made it. You're here to try to understand why you made it. I thought you'd have figured that out by now." The Oracle, Matrix Reloaded
