Renault ECUs impounded
gridwalker
gridwalker
https://www.motorsport.com/f1/news/rena ... t/4557425/
Anybody care to elaborate on what the specific infringement may be?
Sieper
119
Re: Renault ECUs impounded
Brake balance changed automatically as per number of meters traveled. E.g driver aid.
Just a personal interest, a Family recreating a WW2 May 1940 Dutch warbird from scratch: https://www.facebook.com/FlyingFokkerD21/
Marc.W
gridwalker wrote:
Sun Oct 13, 2019 8:04 pm
From another article:
"Racing Point alleges the team’s two cars include a “pre-set lap distance-dependent brake bias adjustment system”. This is forbidden by article 11.1.4 of the technical regulations which states “any change to, or modulation of, the brake system… may not be pre-set”."
Can't we just go back to simply having a fixed brake bias set for the session and it's no longer able to be operated by the driver during the race?
that way we wouldn't have this stuff going on, and we can have the drivers keep their hands on the steering wheel instead of changing stuff every corner.
bring racing back.
Dumpster sounds so much more classy. It's the diamond of the cesspools.
Maritimer
Maritimer
22
When was the last time brake bias was fixed? 60s? 70s? Every F1 car ive ever seen the inside of at least had a knob the driver could use during the race. Besides, bias controls are on the wheel so theres no removing the hand to twist a handle anymore, it's the press of a button.
raymondu999
150
I don't think a fixed setup brake bias, and a knob-changeable brake bias are actually workable in the current F1? Due to braking energy recovery which would surely mean a mechanical, "static" (for that braking zone, at least) brake bias would lead to many rear lockups
失败者找理由,成功者找方法
marmer
marmer
34
am i the only one that doesn't understand why renault might have done this. its not making the brakes better its just saving the driver a job that they don'y seem to struggle with unless its actually doing a bit more illegally we don't know about. it just seems to risky for a team to do for no real improvment
Jolle
Jolle
215
marmer wrote:
Mon Oct 14, 2019 2:31 pm
Convenience for the race and precision for qualifying. You can program the brake bias more accurate from sim data then a driver can set between corners.
bigblue
36
Maybe the bias changed between every corner. Not sure a driver would be fiddling around that much, so sort of a driver brake aid ? Just speculating.
Anyway, how did Racing Point figure this out ? Examination of onboard images ?
aleks_ader
88
In theory this could even be ABS like system. NO?
henry
317
The brake balance needs to be adjusted to accommodate differences in load transfer at initial brake application. This depends on aero load, higher speed more aero load, higher braking force, more load transfer. It also depends, to a lesser extent, on road gradient. They may also like to take account of road grip.
They may have pre-programmed each corner but if they really wanted to automate it they would take aero load from air speed measurement and adaptively modify for road grip and gradient.
Maritimer
Maritimer
22
bigblue wrote:
Mon Oct 14, 2019 8:21 pm
The drivers change bias for almost every corner, it's just two buttons they press with their thumbs, not much fussing around. Two clicks up for this corner, one down for the next, etc.
Zynerji
Zynerji
96
Maritimer wrote:
Mon Oct 14, 2019 11:11 pm
Realistically, if the computer was continuously crunching optimal solutions, that button press could just load the current optimal. It would be more like a driver activated pre-load than any skillful mastery on the "feel" of the car with an analog knob adjustment.
The line here can be blurry, I feel.
piast9
piast9
27
As far as I understood the Renault's trick was to apply the pre-programmed brake bias settings as each lap progressed. If so there was no computer aided optimization but it was still illegal.
bill shoe
bill shoe
253
Renault issued a press-release with typical positive/confident tones-
“Renault F1 Team acknowledges the protest lodged by SportPesa Racing Point F1 Team concerning its brake bias system following the Japanese Grand Prix,” the statement read. “Team representatives have met with the stewards of the event at Suzuka, but due to the complexity of the 12-page dossier prepared by SportPesa Racing Point F1 Team, a further meeting will take place at a future date, to be defined."
“Renault F1 Team intends to use this recess to prepare an equally detailed case to rigorously defend its position.”
https://racer.com/2019/10/13/racing-poi ... dmissible/
Hmm. The Renault quote is conspicuously different than the logical statement if they were innocent: "We did not use a system that adjusts brake bias according to position/distance on track."
