Single Cylinder Crankshaft Oil Drilling
coseng
coseng
Re: Single Cylinder Crankshaft Oil Drilling
>>180 deg in the upper main is more than enough for the rod bearing. It is not unusual to have a groove of less than 180 deg such
Thanks. A 170 degrees or so groove in the upper bearing half sounds like the way to go.
Chris
Cosentino Engineering
www.cosentinoengineering.com
coseng
coseng
Just to follow up, some more internet digging turned up clevite's catalog which backs up your 'less than 180 in the upper only' groove advice. It says a 140 degree groove in the upper is about optimum.
https://www.mahle-aftermarket.com/media ... -40-16.pdf
Chris
Chris
63l8qrrfy6
63l8qrrfy6
368
Well I did use to work for Mahle!
coseng
coseng
Not your average forum troller!
Chris
coaster
You can use the oil drilling to core out the main journal thus reducing mass, better for rpm, maybe buy an old f1 conrod TJ if it suits the stroke youre aiming to use.
coseng
coseng
Both ends of the crank will have a large retaining bolt so will be drilled as much as allowable.
For the conrod, Carrillo's custom rods are not too pricey so not worth trying to adapt a part from something else.
Chris
