Testdrive wrote: ↑08 Dec 2020, 04:36
How were the tests done? 241KM with full front and rear wings? like a Monaco setup?
You're asking similar questions in two topics, so lets answer it all in here.
Those numbers from the Agathangelou/Gascoyne paper were from wind tunnel data, at the time probably 40% scale model at around 40-50m/s. But that doesn't really matter because aerodynamicists use coefficients, because they are insensitive to speed/atmospheric conditions, and F1 cars are fairly Reynolds number insensitive - i.e. there is no boundary layer state of flow change at race speeds assuming a constant car attitude - so forces scale quite satisfactorily from wind tunnel tests.
Downforce squares with speed and cooler/denser air means downforce increases, by the following equation:
where F is the lift force in Newtons,
is air density, U is the velocity,
is the force coefficient, and S is the frontal area. There is a legacy value for the frontal area of
which has been used in F1 through the years and
for ISA conditions is
. So taking the peak coefficient (from 1992) from the table JJR supplied from that paper in the other topic of 3.04, I get a downforce of 12,165N at 240kph, with 3,698N of drag - up to 21,627N:6573N at 320kph. Power from the engines around that point would be 700-750bhp so from the drag and an assumed efficiency of 80% I get an back of envelope top speed between 285kph and 295kph.
The track they presented data for was probably Barcalona, because it's the main test venue. They also were for Tyrrell, which while a good team was not the team it once was through the 90s - so expect at least 20% more downforce for the top teams at that time (the gaps will be narrower now). There is also a tendency for F1 teams to obfuscate their data because they don't want to give anything away to an opponent so there really is very little real data out there to compare to.
You've also failed to satisfactorily answer the question of what the lookup tables contain, could it be you're just adjusting some baseline while the variable is the default?!
