Alpine A521
Re: Alpine A521
Something is going on under the gearbox, in the boat-shaped area at the center of the diffuser
Re: Alpine A521
LM10 wrote:
12 Mar 2021, 12:31
Blackout wrote:
12 Mar 2021, 12:18
LM10 wrote:
12 Mar 2021, 11:28
Alpine mounted the rear wishbone to the crash structure, so following Mercedes as well.
https://mediaproxy.tickaroo.com/v3/imag ... 3665a5135c
via AMuS
No.
Then AMuS is not right. :)
Dunno what they're talking about. Geometries look conventional and very similar to 2020. Only big difference is the raising of the top wishbone .
Re: Alpine A521
Blackout wrote:
12 Mar 2021, 12:43
A brighter, higher resolution photo via @f1debrief
Re: Alpine A521
Thanks.
Re: Alpine A521
The Mclaren too has a big clearance over the diffuser on the boat-shaped area under the gearbox. The latter seems to end where I ve put the yellow arrows
But on the Alpine, the Gbox bottom seems to stop a bit earlier
Big difference between the diffusers too... (white arrow)
Some diffuser somehow have a much more aggressive kick-up area and slope than others...
Re: Alpine A521
Good illustration of how low profile the mclaren rear suspension is. The upper and lower arms are closer together in height.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
aerofoilf1
aerofoilf1
247
Re: Alpine A521
Changes to the front brake duct and rear wing/t-wing
aerofoilf1
aerofoilf1
247
Re: Alpine A521
Diffuser comparison to 2020
GoranF1
GoranF1
155
Re: Alpine A521
Heard something about using airbox to produce venturi effect, to improve rear wings Effectiveness.
What do you guys think?
Re: Alpine A521
Re: Alpine A521
PlatinumZealot wrote:
12 Mar 2021, 15:53
Over the last Decade, McLaren have been lacking in Mechanical grip. So I'm not sure if you're saying it's good to be different from them or just stating it as neither good or bad, just that it is different?
gosswilliams75
Re: Alpine A521
Beautiful perspective :
Steven
Owner
Re: Alpine A521
GoranF1 wrote:
12 Mar 2021, 18:14
For a venturi effect, you need two surfaces. I don't see how this could apply to the airbox.
Coanda maybe?
Anyway, a narrower airbox is certainly better, but everybody has to have one by the rules. It's just a matter of tradeoff for the design team to decide where to put which component.
Re: Alpine A521
By the way, the rollhoop cover has been extended today
gosswilliams75
Re: Alpine A521
If we suppose that the Alpine went a little the opposite way than Ferrari between 18 and 19, and moved part of the cooling of the pontoons to the chimney, curiously the pontoons inlets shrank but those of the chimney remained the same ... as the chimney grew ...
- There has certainly been a relocation and reorientation of the CCS (central cooling system), not just an addition of radiators
