Alpine A522 Speculation Thread
wogx
This photo was posted on Twitter for a short time, then it got deleted from Reddit & Twitter. On one hand the FWEP look like 22' spec, on the other hand rear wing looks more like a 21', I do not see that rounded corner mandated by 22' regulations:
geraldix
geraldix
Re: Alpine A522 Speculation Thread
I also see a rather high, thumb-tipped nosecone. It's probably just a frankenstein show car for livery reveal purposes.
BlueCheetah66
BlueCheetah66
32
That's a very confusing image. The front wing endplates look like the 2022 design and not the FOM model. But the nose seems to be a thumb nose or some sort of variation. Then there are only wheel fairings on the left side. The sidepod looks tighter than the 2021 car but then if it is the 2022 car is looks like it has a fairly high rake
Jolle
Jolle
It’s the post season tire test mule.
wogx
It looks that you're right, @Jolle! Sharkfin, mirror position & few more details match :)
FWEP and rear wing main plane look different
Scalexf1
Scalexf1
wogx wrote:
16 Jan 2022, 01:19
https://www.grandprix247.com/wp-content ... esting.jpg
https://formularapida.net/wp-content/up ... AEOMk1.jpg
https://www.wykop.pl/cdn/c3201142/comme ... 1gw3sm.jpg
Ignore the teaser, as it’s just that.
Nice prep bay.
FW17
168
The side pod turing vane, are the still allowed?
Nano4k
can i predict the biggest airbox on grid for 2022? ^^
Nano4k wrote:
11 Feb 2022, 22:43
The 2021 Alpine fat airbox was just a temporary, unscheduled, last minute change, just like the 2021 rule changes. It was a compromised design, not an optimised one.
It didnt contain some advanced or clever new trick, it contained a very conventional centerline cooling system (at least layout-wise).
It was fat because the conventional cooling was shoehorned inside a 3 years old chassis that was specifically designed for a different cooling system*.
That's why it was fat.
*So the reasoning behind the Alpine A521 thick air box is simple:
- The FIA has decided to cut a portion of the floors in 2021 to reduce downforce.
--> Alpine has decided to slim down the sidepods to recover some floor surface and DF
--> to do so, they had to move a part of the cooling from the sidepods to the center of the car
--> problem nr1: they already had a cooling system in the center of the car. It was different from the other cars and was contained in a tight space above the engine. So Alpine couldn't really enlarge it.
--> so Alpine decided to move it to the back of the car, where there is more space, so in a very conventional position, similar to the other teams.
--> problem n°2: the original Renault cooling system was fed by the lower air intake of the chassis, while the turbo was fed by the upper air intake, the opposite of the other teams.
--> Alpine didn't want to modify its chassis, which was frozen since 2019, by reworking its structure and internal aero and by reversing the air intakes.
--> So Alpine had to split and spread out its turbo air duct in 2, so the new cooling air duct can pass in between. Hence the widening of the engine cover/roll hoop cover
--> Alpine took advantage of this widening and has put a wide central radiator in that space.
The 2022 cooling system will be completely different and tailored for the 2022 chassis, and vice versa, like the 18, 19, 20 cars, and unlike the 21 car.
Nano4k
wow. thanks for the informations. i really hope it will be a slim car.
next question would be, will they run with a completely new engine? :)
if they do, can there be a change back to the old engine, if their engine isnt improving?
the EDGE
the EDGE
67
Nano4k wrote:
12 Feb 2022, 11:02
If their engine is not an improvement and they would rather be running the old one then to be quite Frank, and with no disrespect meant… they’d be better just to pack-up, go home, & sell the team!
GoranF1
GoranF1
155
Some Alpine engeneir said on Twitter their car will look different to what was seen so far.
olahOPO23
olahOPO23
GoranF1 wrote:
12 Feb 2022, 19:30
Source?
Pandamasque
GoranF1 wrote:
12 Feb 2022, 19:30
Perhaps they'll go full teapot on us and package everything into the engine cover and do away with sidepods altogether! Just have a couple of impact absorption beams sticking out of the chassis :lol:
