Red Bull RB18
Re: Red Bull RB18
vorticism wrote:
31 Mar 2022, 20:31
Further example. This is surely critical detail. Also seems to have curved bottom edge.
https://pbs.twimg.com/media/FOOBjISXMAE7AgW.jpg:large
Vanes are important, though it's hard to analyze them accurately enough based on partial photos. Front end of the floor is the most advanced of any on the grid. Beam wing is also very interesting... Contrary to it, F1-75 floor front end looks almost underdeveloped. It's different philosophies yes, going along with different sidepods, but some details just look really well thought-out...
#Aerogimli
Big Tea
99
Re: Red Bull RB18
Miha_v wrote:
01 Apr 2022, 11:13
Holm86 wrote:
01 Apr 2022, 11:11
Miha_v wrote:
01 Apr 2022, 11:03
Scarbs talking abot a radical new thing RB is doing tu cure porpoising: non-newtonian fluid filled damper AKA "the custard damper."
Quite interesting!
https://twitter.com/ScarbsTech/status/1 ... e2kCSDFrlw
Yeah, look at the date mate ...
"Sshh" :lol:
Well I fell for it :oops: I was about to come here and ask how it distinguishes between suspension movement and bumps.
Doing it on purpose or doing it on porpoise. (I'm a buffoon, the thick in thixotropic )
Mchamilton
Mchamilton
Re: Red Bull RB18
Vanja #66 wrote:
01 Apr 2022, 13:15
vorticism wrote:
31 Mar 2022, 20:31
Other teams will be loving this picture im sure. The contour the the bottom edge of the inner vane is interesting
vorticism
323
Re: Red Bull RB18
dialtone wrote:
01 Apr 2022, 18:22
wowgr8 wrote:
01 Apr 2022, 11:30
"I'm sure Newey foresaw it in the design phase and worked on the mechanics as well as the aerodynamics to solve it.
If Red Bull's solution to porpoising is mechanical they'll have that advantage over everyone for a really long time, I know redesigning suspension is a lot tougher than aero upgrades
In pre-season testing they said to have introduced a suspension that behaves differently above 250kmh.
https://www.sportskeeda.com/f1/news-red ... journalist
And indeed Horner said that both cars were going to be running the new suspension:
I wouldn't know if solving it aerodynamically or via suspension is better/easier or worse/harder, but Ferrari doesn't seem to have trouble in the traction areas and in slow corners so I don't think their suspension puts them at a particular mechanical disadvantage today except for porpoising.
There will be a drag component to porpoising in addition to the vertical forces, so I wonder could their anti-dive geometry will help with this at all.
𓄀
Edax
Edax
47
Re: Red Bull RB18
I can’t help but wonder whether the AM-RB001 Valkyrie fits somewhere in the evolution of this car.
Of course the cars are probably too different to literally test or take over components, but could it be used as a studyobject to for instance take out correlation issues?
Andi76
Andi76
397
Re: Red Bull RB18
vorticism wrote:
01 Apr 2022, 20:18
dialtone wrote:
01 Apr 2022, 18:22
wowgr8 wrote:
01 Apr 2022, 11:30
I remember Scarbs saying Red Bull uses a Pro-Dive-Suspension. I never was able to find a really detailed image of the lower wishbones, but if the rear lower wishbone is not placed significantly higher than the front one, Scarbs is probably right. From some not very detailed pictures i would say Ferrari uses a similar suspension geometry, just a less extreme version than the Red Bull. I am not a specialist in suspension geometry, but if Scarbs is right with Red Bulls "Pro-Dive"-suspension geometry, i would say both cars use a "Pro-Dive'-suspension. But as i said - i am not a specialist in suspension geometry and i hope there are some people in here with better understanding and knowledge who can clarify that.
Re: Red Bull RB18
With more performance from the floor, wouldn't you also have to move the brake bias towards the rear a bit? One knock on effect with a very efficient floor, is slightly more MGU-K recovery because you're using more of the rear axle for braking.
We often saw at night races, the brake bias on the previous generation cars was ~58-57 forward biased, if the new cars are 54-53, that's an extra 4% more braking done with the rear axle. So assuming some losses perhaps an extra 2-3% MGU-K harvesting vs a team with a less efficient floor.
raymondu999
Re: Red Bull RB18
godlameroso wrote:
05 Apr 2022, 01:47
the current CofP should be around the throat of the venturi no? Which iirc is not really rear-biased
失败者找理由,成功者找方法
Curbstone
Curbstone
Re: Red Bull RB18
Well the shape of the floor is not really a classic venturi example with a simple shaped throat, so I am also curious where the CoP would lie.
raymondu999
Re: Red Bull RB18
Curbstone wrote:
05 Apr 2022, 11:29
That is true. There were also some images of the RB having a touch of rake too; which would perhaps — even with a conventional venturi shape — shift the CoP backwards a touch
失败者找理由,成功者找方法
Re: Red Bull RB18
raymondu999 wrote:
05 Apr 2022, 12:03
CoP is shifted forward with positive rake :) Or did RB lower the rear end actually?
#Aerogimli
Re: Red Bull RB18
Vanja #66 wrote:
05 Apr 2022, 12:17
raymondu999 wrote:
05 Apr 2022, 12:03
The Mercs were pictured with what appeared to be "negative rake" apparently trying to get more rear end downforce.
Re: Red Bull RB18
Re: Red Bull RB18
SiLo
135
Re: Red Bull RB18
Check the curl on the third strake on the right hand side. It's not just a flat strake. Interesting that it looks like it curls towards the centre of the chassis.
Felipe Baby!
