5-lug wheels on an F1 car.
Zynerji
110
https://imgur.com/a/IhH6Qsi
I'd embed, but would need a bit or help to do so...
These event tyres shook me when I saw that they were 5 lug wheels. They must have made an adapter? Maybe put some iron brake rotors on as well?
jjn9128
769
Re: 5-lug wheels on an F1 car.
probably the same sort of adapter being used by kevt on twitter -turning his caterham into a track day car.
I'd imagine not carbon disks too because of operating temps.
#aerogandalf
Stu
Good spot! The centre-nut is still visible, so I would imagine a simple aluminium adaptor. No need for different discs, but maybe some help with pad materials to get them to work at low temperatures/speeds; carbon-carbon are notoriously temperature dependent.
Big Tea
99
Would there be any advantage in having 5 stud fitting? More stud nuts to 'push against' may be but the wheels do not actually drive by the wheel but splines at the hub. It would not gain anything would it?
As mentioned, I would think an adaptor to fit a wheel suitable for those tyres.
Airshifter
They might possibly just be dummy nuts as well to make us think it is more like a normal street wheel. Max put on his ice tires and went for a drive.....
Good catch though. When I saw the thread title I thought maybe someone had smoked a big breakfast!
JordanMugen
82
Speaking of wheel nuts, I didn't realise they run left-handed threads on the left side of the car. In hindsight it is an obvious safety measure, but it is a nice little touch nevertheless. :)
In the below thread folks seem to say is the opposite, but unless I am mistaken that is the left front with the mandatory FIA air deflector?
viewtopic.php?t=11503
I.e., the assumption is that normal forward rotation being in the same direction as the wheel nut thread for a self-tightening failsafe is more important, unlike the assumption in the thread of braking generating more g's and wanting to undo the wheel nuts in the opposite way to forward rotation.
