2022 Azerbaijan Grand Prix - Baku, June 10 - 12
Re: 2022 Azerbaijan Grand Prix - Baku, June 10 - 12
lh13 wrote:
12 Jun 2022, 20:09
PlatinumZealot wrote:
lh13 wrote:
12 Jun 2022, 18:12
You have difficulty reading?
Reading is one thing but it is clear you are having trouble with comprehension!
To explain it better for you, age and weight makes a difference for athletes. The older and heavier you are the more you feel jolts in the joints.
https://streamable.com/pc0ev0
You say that McLaren is the least effected car while Norris clearly mentioned that they're compromising on the performance to manage the situation...
Sure they are. And where were they in Barcelona where the track is flat as a billiard table?
lh13
lh13
lh13 wrote:
12 Jun 2022, 20:09
PlatinumZealot wrote: Reading is one thing but it is clear you are having trouble with comprehension!
Irrelevant!
Big Tea
99
chrisc90 wrote:
12 Jun 2022, 20:13
Mchamilton wrote:
12 Jun 2022, 20:11
chrisc90 wrote:
12 Jun 2022, 18:24
Why cant they just raise the car to give it a bit of rake so the rear is higher than the front? That way there is more travel for the rear to be pulled down under the higher speed running, meaning the floor is less closer to the floor and reduces the chance of porpoising as the floor doesnt stall.
Maybe why this is why the RB is so good, because they are used to running rake on their cars?
Because that would sacrifice performance around the entire lap
Correct. But there must be a cross over somewhere though.
Thats like saying why not put the bar lower in highjump so everyone can do it. Even the athletes struggling would say ' no, up a little more'
Shrieker
Ferrari big rip. They just imploded.
At this rate, if merc manage to fix their car (however doubtful that may sound), russell has a better shot at the title than Leclerc.
-Atatürk
chrisc90
37
Shrieker wrote:
12 Jun 2022, 20:44
17 points behind. I was quite shocked when I looked that up after reading your post.
Big Tea
99
Shrieker wrote:
12 Jun 2022, 20:44
Can not see anyone catching RBR now. The only snag could come if the two drivers start scrapping and getting DNF's
Schuttelberg
Mercedes have finally accepted that they cannot fix the bouncing without losing performance so Russell, Hamilton and Wolff are going to go into a PR overdrive to make this out as a safety issue.
chrisc90
37
Schuttelberg wrote:
12 Jun 2022, 21:16
Its certainly whats coming across on the media. And they are making a big deal of it.
I really hope the FIA is smart enough not to fall for such tactics
lh13
lh13
Nothing can be discounted, given that the FIA is not the most 'competent' organisation in the world.
siskue2005
70
chrisc90 wrote:
12 Jun 2022, 21:22
Schuttelberg wrote:
12 Jun 2022, 21:16
Similar tactics used by every other team since the dawn of F1.
siskue2005
70
Schuttelberg wrote:
12 Jun 2022, 21:16
Sainz, Leclerc, Magnussen, Riccardo are also with the Merc PR team I belive :D
Maybe all of them are hoping to get a merc drive soon, or it must be a genuine issue
Big Tea
99
siskue2005 wrote:
12 Jun 2022, 21:28
Schuttelberg wrote:
12 Jun 2022, 21:16
lh13
lh13
siskue2005 wrote:
chrisc90 wrote:
12 Jun 2022, 21:22
Schuttelberg wrote:
12 Jun 2022, 21:16
That is true. Its FIA's job to decide what's actually needed and what's only noise.
siskue2005
70
lh13 wrote:
12 Jun 2022, 21:29
siskue2005 wrote:
chrisc90 wrote:
12 Jun 2022, 21:22
If its genuine the FIA will act. I hope they look at it objectively
Tvetovnato
Tvetovnato
What is there to look into for the FIA really? It’s a bit of a nonsense issue. If the porpoising is so bad for some teams, there is a way to solve it - raise the car until you find another solution. No one is obliged to help you.
Same for the teams complaining about having to miss some races or they will fail to adhere to the budget cap - stop development of the car is it’s required to save money.
Both of these things costs lap time, sure. But the playing field is the same for all, so deal with it.
