Decent 3d models for CFD
christian.falavena
Hi all, I’m trying to do a CFD sim for an F1 floor. The main problem is that every solid model on the web has straight strakes and not turning on outside, so it’s a completely messed up design.
I found a decent model but it was only in STL format, so impossible to do a CFD with.
If anyone has some decent car models please suggest or help me. Thank you very much
beschadigunc
beschadigunc
Re: Decent 3d models for CFD
You can ask MVRC crowd to donate their year old car. Doubt you will find anything good in internet otherwise
Koldskaal
christian.falavena wrote:
01 Jun 2023, 14:35
In MVRC we only use .stl for the geometry. So it's not impossible :D . SnappyHexMesh happily accepts stls as input.
MVRC - Koldskaal, name: Christian
thebot
thebot
the .stl file is only for geometry and to create a mesh so maybe you can do it in simflow 4.0
Billzilla
Billzilla
Can't you save the STL into a different format that you can use? I use Solidworks and you can save nearly anything as nearly anything else.
christian.falavena
01 Jun 2023, 14:35
Yeah but when I try to simulate it, it results as a zero thickness surface, and with every 3D tool it’s impossible to thicken it because it’s a complex model
yinlad
The issue is that it's modelled as a surface with no thickness rather than it being an STL then
MVRC - Panthera
christian.falavena
yinlad wrote:The issue is that it's modelled as a surface with no thickness rather than it being an STL then
Is there a way to solve this?
Racingf1
Racingf1
05 Jun 2023, 14:06
Ansa would be your friend to do the geometry clean-up.
https://www.beta-cae.com/ansa.htm
