Are there alternative Radiator Coolants out there besides anti-freeze from petro-chemicals?? Can you make them at home?? Are they affordable, and what do they use in F1??
Thanks,
Gear
Oddly also if piss on some cloth it will protect you against some gas attacks (WW1 info there)manchild wrote:Works with frozen key locks tooTom wrote:just piss in your radiator.
Gear... just to be accurate, the bit of the name that determines the functional group is the end, i.e. -ol; that is the part that tells you its a kind of alcohOL.gear_dawg wrote:It would seem that most coolants are of the alcohol type, hence the name(s). Ethy, Methy, ect, ect...
I read ethylene glycol is not toxic. However, the byproducts, once you metabolize it, are toxic. http://www.emedicine.com/emerg/topic177.htm (mentions 16 deaths per year in USA).Mikey_s wrote:...Finally, although it could not be recommended to drink radiator fluids, ethylene glycol is not very toxic...
