It´s a plug in hybrid which means it´s main propulsion comes from electro motor and uses a small ICE for charging the batteries when needed.
My goal is 350+ bhp, 600+ Nm, 0-100 less then 4,5sec and V-max 270+kph
But I´m going to need some help from you concerning aero, suspension, component placement....
So there vill be quite a few questions from me on this topic, hope I´ll get help
My first question: should i locate the motors in the wheels and don´t use gearbox or to locate the motors inside and use a gearbox?
From what I see it´s like this:
Layout 1-with gearbox, will give the car better top speed and better braking but also it will weigh more, be more expensive, it won´t charge the batteries under braking like the second layout and the venturis at the back would be significiantly smaller
Layout 2-in wheel motors
Less expansive, weights less, lives place for other stuff and charges the batteries under braking
Layout 1 [IMG:150:112]http://img442.imageshack.us/img442/1760 ... xq6.th.jpg[/img]
Layout 2 [IMG:150:112]http://img376.imageshack.us/img376/2559 ... qc1.th.jpg[/img]
What do you think guys?
