the most important reason why not 5 Valves is, that 5 valves are very
bad to steer, you nead a very complicated system to trigger the 5th valve,
the diameters of the valveplates are smaller, and the positioning of the
spark plug is most difficulter in the combustion chamber, as with 4 valves... the valves have bigger dihedral angles!!! (bigger cyl.head!!!)
another reason why they dont use 5 valve technology, is the weight, you
have more moved components, you need a bit bigger cylinder head and
the advantage you´ve won with the 5´th valve is lost...
so i hope that helps you a little bit...
Kind regard´s
ROBs ;o)
[email protected]
