I couldn't find anywhere a way how to calculate the force which is generated by the floor of the car, so I tried to do it by myself and now I whant to know if I am on the right way.
I found one formula for horizontal streaming:
p + 1/2*rho*v² = konstant
rho is density of air =1,22Kg/m³
konstand is air pressure when the car does not move
konst.=1bar =100 000N/m²
I put this to
p =konst. - 1/2 *rho *v²
and for kons.=1 bar
so I get
p=100 000N/m² -1/2*rho*v²
Now when the car moves we have a lower pressure on top of the car and a more lower pressure under the car. The difference should be the pressure which presses the car to the ground.
So I calculated the pressure over the car at 16,66m/s (60km/h) and under the car, where the speed is higher because of the venturi like shape of the floor.
top of car
po=100 000N/m² - 0,5*1,22Kg/m²*16,66²m/s²
po=100 000N/m² - 169,3N/m²
po=99830,7N/m² =0,9983bar
under the car
here is the speed higher because of the reduced area
you can calculate the speed by V1/V2=A2/A1
I took the factor 1:2 so we have a speed of 33,32m/s
pu=100 000N/m² - 0,5*1,22kg/m²*33,32m/s²
pu=100 000N/m² - 677,23N/m²
pu=99322,7N/m²
The difference is now
dp=507,9N/m² = 0,005079bar
Lets say we have in average this pressure difference over the floor and
a floor surface of maybe A= 1,5m². So we can calculate the downforce by:
F=dp*A
F=507,9N/m²*1,5m²= 761,85N =76kg downforce
Sounds good, but there is one think I started to wonder about.
If the car drives faster is the speed over the car faster and so the pressure reduced. The speed of the air under the car gets also faster but in the same relation even after taking it into square. So the downforce doesn't depend on the speed of the car. So something I didn't got right.
But I didn't tried it with figures maybe i should.
edit: I am quite shure it is right.
Is is right that the pressure over the car in motion is lower than on a standing car?
