Tomba wrote:Pretty cool idea, but to have a wing you must be able to extract some force out of it.
Now suppose we ignore the downforce generated by elements to create the air wing and let's say the airwing pushes air up, how will you be able to catch the created downforce?
Good question. The only answer I can think of, is out of this world... like all my ideas. So, here we have "Ciro's ionic wing"
It's an original idea, so I have little hope of it working in the real world, but...
What about ioinizing the air? You could use magnets and inductors and a "little" magnetohydrodinamics theory to "shape the air". If air is ionized you could get the force back using inductors or other magnets, if that is what Tomba asks...
I know this is differente from what was suggested by fastback33, but, hey, in principle is a good idea. I just found this:
An aerodynamic study of the "electric wind"
Interesting. So, it could be something like this "awesome" drawing of a nose cone:
Ciro's Magnetoaerodinamic wing: a grid ionizes the air, the flow, in blue, is compressed by "shaping" magnets and the resultant force is taken by "reaction" magnets.
Has this been tested? Any ideas? Should it "compress" the air, as it is "clearly" depicted, to work? Could this be used on the edges between wings with multiple elements?
Ionized air "compressed" between wings with multiple elements
Can you get any "mechanical advantage"? I mean, can you avoid the reaction in the "shaping magnets"? (if they "shape" the wind, they receive a "counterforce", I imagine). Anyway, there are some gadgets (
Ionic breeze) with very low airflows (but significant ones) that work using this principle.
Finally, I imagine this gives you a way to change the properties of the boundary layer... has this been tested? Can the boundary layer be manipulated by charging or ionizing it? For example, in superconducting materials, the ionized layer is very well "defined": this is a principle of superconductivity (what it is called the penetrating depth of the magnetic field).
If this is workable, it would open a can of worms: this is no movable aerodynamic device, but, in principle, it allows you to modify your "electric" downforce by modulation of currents...
BTW, welcome, fastback33.
NOTE: On a different train of thinking, I don't know if you've heard of the use of bubbles or ultrasonic induced cavitation (
Supercavitating Vehicles) to diminish friction on underwater missiles and submarines. Allegedly, US Navy is making tests and some people claim you can reach over 100 mph underwater.
I've been thinking about this for a while. Can this principle used to enhace the "lubrication" of air somehow in a car? I know you cannot create bubbles of air in the air, but can you create "bubbles of void"? Can you inject some gas on the air current that diminishes drag? Would this diminish drag, if feasible? I think of a sort of "Teflon" aerodynamic "material" (actually, it should be some kind of gas, I imagine).
Underwater Express Submarine Utilizes Bubbles for Speed
Well, and some of you thought I could not get any weirder...
