Engine - Odd thinking on this one, so please try to follow...
Engine is a .6L boxer 2 cylindar turbo diesel. That 50-100HP engine would attach to a high efficience hydraulic pump to pressurize hyd fluid. Now here is the trick part, and if it is unrealistic, please let me know... The pump feeds a distribution manifold where 2 feed lines, and 2 return lines go to the nose of the car (more on that later), and another feed/return line goes to a hydraulic motor (Sauer Danfoss makes a 7000rpm/1800lb/ft torque motor) that is then jumped 3:1 creating 21,000RPM on the outshaft. Now the outshaft would plug into a diferential (follow me on this), and one side of the diff would feed into todays standard gearbox, while the other side would feed into an electric motor/generator. the front lines would operate 2 back to back motors that would connect individually to the front wheels by half-shaft.
So, the basic layout is understood. I understand that there would be alot of working the pieces to get them all lined up, and maximize the COG, but that is for the engineers...
Ok, so this is how it works. The Diesel engine drives the pump, and the pump drives the 3 motors independantly. The front will simply drive via trigers (think XBOX paddle) on the wheel, so the driver could completely control the rotation through corners. The rear motor would operate the differential directly. Now the differential would be where all of the magic happens. Since you would have 2 outputs for the diff, one with the gen/motor and the other to the gearbox, you could therefor drive the wheels, with the hyd and the electric motor for accel, and you could then on downshifting and braking use the electric motor as a generator and use the motors in the front as pumps to drive the rear hyd motor just to spin the generator, reclaiming the energy.
The trick is the ele/hyd motor combination. The electric motor could literally be used as a form of TC, as a RPM soak, and as an accelerator. If the hyd motor is producing way more torque than the car needs, you may see it spinning the generator as well as turning the wheels. The key here tho is the independently operated front wheels. THAT would be the greatest thing that I have ever seen on a racecar. Unfortunately, it would only serve to increase cornering speed, and we all know how much the FIA love that!
Anyways, a LiPo battery would replace half of the gastank area, the conglomeration of my pieces would need to be refined to fit inside the box, and since it is air cooled, the radiator ducts would shrink almost completely.
I have this thing about hydraulic drive systems, and I cannot for the life of me find the single point failure that keeps them out of production automobiles other than a lack of ACTUALLY MAKING ONE.
Anyways, my daydream is all here for you guys to poke holes in, so please feel free to do so, patching those holes will give me something to think about tomorrow!
Chris
