2005 Novelties
bar555
bar555
2005 Novelties
Here is the first thread of this kind
Mc Laren introduced in 2005 the famous NO KEEL chassis and the VIKING HORNS
In 2005 the FIA once again raised the front wings outer tips and again the emphasis on the obstruction behind the wing was a higher priority. McLaren were having already run very drooped front wishbones were able to devise a better layout for the front of the car.The team managed to mate the wishbones directly to the chassis . This is a stiffer lighter set up and also creates the free space under the nose so as to improve the nature and speed of the airflow under the body of the car .
Since then many teams copied the no keel design and in 2007 all the team's chassis ( except Renault) and in 2008 are keel-less .
Their purpose are to divert and guide airflow towards the rear wing to increase downforce
Since then only BMW F1.06 – 2006 season , F1.07 – 2007 season and F1.08 – 2008 winter testing and Honda RA108 – 2008 winter testing copied them . Mc Laren dropped them since mid 2007 season .
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
PNSD
PNSD
Re: 2005 Novelties
Thats from scarbs isnt it ?
And toyota had zero keel on their 2004 B spec car at Suzuka I think.
bar555
bar555
Re: 2005 Novelties
Yes , the Keel-less description and the drawing is from Scarbs .
Toyota TF104B in 2004 was a single keel Car . Toyota TF106 and TF106B in 2006 were the first keel-less chassis the team ever made .
PNSD
PNSD
Re: 2005 Novelties
Sorry I meant the TF105B. That was the first toyota zero-keeled car.
bar555
bar555
Re: 2005 Novelties
That is partially correct because the single keel was not disapeared in TF105B as it should be . The first really keel-less Toyota was TF106B in 2006
megz
Re: 2005 Novelties
The very first front wing with a full upper element, the Sauber C24
(Hope I'm not wrong, the design was never raced and the first front wing like this to be raced I believe was the BAR at either Spa or Suzuka along with the first of the sidepod shields that we are used to today, I think.)
bar555
bar555
Re: 2005 Novelties
I think that the very first team to use a front wing with an upper element was Prost AP04 2001 in Monaco GP . Ferrari F2001 tested it before Prost but never used it in 2001 .
megz
Re: 2005 Novelties
O, wow I lose BIG time haha on a Prost in 2001 dang...
bar555
bar555
Re: 2005 Novelties
In 2005 Renault introduced a revised keel arrangement, dubbed the V keel, this was effectively a single keel layout but the usual solid shape of the keel was altered for a hollow “bracket” this freed up some airflow and also the keels shape was more structurally efficient, making it lighter ( by Scarbs )
bar555
bar555
Re: 2005 Novelties
This feature helps to provide better management of the airflow directed to the rear of the car and to reduce side wing influence especially when turning. Since then almost every team adopted a similar feature and Red Bull RB4 in winter 2008 testing introduced a huge one
Steven
Owner
Re: 2005 Novelties
In regards to the TF105B, that car was a development of the TF105 mainly in its suspension geometry. The team had changed from attaching the lower wishbones to the monocoque instead of to the keel. However, strangely they did not remove the keel until the next season.
In all the struggling history of Toyota, I consider this actually a highpoint. It was in the midst of their problematic seasons and such design philosophy certainly did not help.
A novelty in 2005 are also the mass dampers as introduced by Renault. They ran them in Brazil after getting approval from the FIA. Then they were controversially banned as of Hockenheim 2006 :shock:
scarbs
scarbs
393
Re: 2005 Novelties
Here's my list from my Autosport updates...
Rear wing support – Honda Toyota,
Deeply undercut sidepods, Mac Sauber
V-keel Renault
Dolphin vertical splitter above T tray, Renault
Heavily louvered sidepods
Conjoined Chimney T-wIng Red Bull
Pod Wings not mounted to side of chassis but solely to sidepods (Jordan)
Chin Wing on front wing Ferrari
Rear Wishbones through the diffuser Renault
Brake ducts enclosing rear disc, Williams
Mac zero keel suspension and routing torsion bars through the top of the nose
Toyota Zero Keel suspension, Single keel chassis
Everybody adopting cascade FW endplates
Tyre cameras in huge pod above Williams or in BARs sidepods
Renaults odd tunnel on the FW endplate
Fins on front brake ducts Ferrari and Toyota
Grooved brake discs, McLaren
Flip ups and vanes at rear edge of bargeboards
Extra channels in diffuser Ferrari BAR
Fin on nose Renault
Joining chimney to T wing endplate Ferrari
bar555
bar555
Re: 2005 Novelties
Thanks Scarbs ,
Here is one not included in the list
To increase downforce at Monaco ,Toyota mounted extra winglets using tiny pillars on top of the main front wing profiles. Their purpose was to add front-end sharpness to the car on entry to corners . It was the first time that T-Winglets were spotted away from the main body of the car . Since then the desigh was abandoned and never used again .
sebbe
sebbe
1995 Novelties
1995 Novelty...
MP4-10 was an interesting car. Look at the shape of the engine cover, now look at the Red-Bull picture
Image Image
Anyone can tell me which year is that Red-Bull?
More info at: http://www.f1technical.net/f1db/cars/771
I haven't been able to find more about this car, although I remember reading it didn't go well for McLaren that year.
You can also see a first glimpse of the viking horns in the MP4-10 (called by somebody as the ugliest Macca ever).
Anyone has more insight on the car?
"I've already altered the deal, pray I don't alter it any further" -Darth Vader to Lando Calrissian. The Empire Strikes Back.
"Progress is not always made by reasonable men." (McLaren Racing).
"We have optimised the lateral optical interface of the building." (Translation: "My factory has a lot of windows.") Ron Dennis.-
Rob W
Re: 1995 Novelties
sebbe wrote:Image
This year... earlier testing.
R
