Torro Rosso STR2B/3 aero mech development in 2008
bar555
bar555
GP AUSTRALIA MELBOURNE
FRONT WING
2 plane wing with a bridged element . The endplates had a vertical leading edge and a small winglet .
REAR WING
Small cut in the middle of the wing. The airflow onto that area of the rear wing is actually slightly disrupted by the airbox ahead of it. Cutting this tip out prevents the generation of unwanted drag for very little downforce.
DIFFUSER
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
bar555
bar555
Re: Torro Rosso STR2B/3 aero mech development in 2008
CHIMNEYS
EXHAUSTS
Periscopic exhaust pipes
INDY FINS DETAILS
HKS
Racing cars are neither beautiful nor ugly, they are beautiful only when you win races.
bar555
bar555
NOSE CAMERA STYLE WINGLETS
Camera winglets were attached on both nose cone sides
MIRRORS
Ferrari style mirrors , placed away from the cockpit so as not to disturb the airflow towards the rear of the car
NOSE CONE END HOLE
Helps for cooling cockpit and nose cone electronics
bar555
bar555
STEERING WHEEL
GEARBOX
Seven speed gearbox. Longitudinally mounted high-pressure hydraulic system for power shift and clutch operation. AP racing triple-plate-type clutch
SHARK GILLS
Two venting slits on both top frontal sidepods area , just above the radiators , This slits help extracting hot air
bar555
bar555
T WINGS
Double plane T Wings
BARGEBOARDS - DETAILS
2 sets of bargeboards , one inside the front suspension and the other , the large ones , in front of the sidepod inlets
bar555
bar555
GP MALAYSIA SEPANG
STEERING WHEEL
DIFFUSER
Similar to Australia
EXHAUSTS
bar555
bar555
FRONT WING
REAR WING
SHARK GILLS
bar555
bar555
GP BAHRAIN SAKHIR
FRONT WING
Similar to Malaysia
REAR WING
bar555
bar555
GP SPAIN
FRONT WING
Bahrain front wing spec was only used during FP1 & FP2 during Bahrain GP . The Spanish version was similar to Bahrain's race version
REAR WING
bar555
bar555
CHIMNEYS - SPAIN
The right chimney was semi closed
SHARK COOLING GILLS - SPAIN
Asymmetrical cooling gills , 2 slits only on the left upper side of the sidepods
bar555
bar555
DIFFUSER - SPAIN
No obvious change
EXHAUSTS - SPAIN
No obvious change
