Which team will use mechanical flybrid?
Scania
Scania
is it Renault?
if not, which will?
dumbdave
dumbdave
Re: Which team will use mechanical flybrid?
I would put money on Renault, Flybrid Systems produce a mechanical flywheel KERS designed for F1 & the company was started & run by ex-Renault engine designers (made redundant with the engine freeze) so they are likely to have ties there, which to my mind means the are most likely working with Renault.
WhiteBlue
92
Williams will use Flywheel. Renault will probably do a Magneti Marelli eectronic system.
Scania
Scania
WhiteBlue wrote:Williams will use Flywheel. Renault will probably do a Magneti Marelli eectronic system.
Williams will use Flywheel > elect system
