WhiteBlue wrote:KERS is under SECU control. The FiA would stop any program using unwanted TC.
Yup, i think that the FIA will not want something like implementing traction control with this. But already, i don't think that the SECU can do everything that is needed to run the system. Considering that the SECU should handle a lot of sensor inputs, add to this the sampling time, control and switching of the electronics at a rate near 20kHz, and all this should be attended by the interrupt routine of the CPU. Maybe its necessary to use a standalone unit, controlled by the SECU in some fashion, and this interface will be standard.
And consider that the battery needs special charging controls to prevent overheat, overcharging and things like that.
Apart from this, i think that is very possible that some team will found a loop hole somewhere, to implement some system of this kind. As joseff pointed out, they will need to check if the input-output energy restrictions allow this kind of implementation.
If we don't consider the limitations for a moment, nothing prevents in the control of the motor/generator to provide a torque that will counteract the one going from the wheels, its only a change in the control zone of the motor. But this will be against the need to store energy, so you would be effectively burning energy, not saving it with the braking. Maybe it can be switched freely from T/C mode, and push-to-pass modes with a button?.
From what the news say, BMW is already tinkering with this kind of T/C system. We will have to see the first implmentations of this systems to understand more what the teams have found that works.
I think that the system has a specific location in the drivetrain, and because only one motor can be used (from the mounting parts of the rules) the two wheels can only be controlled in a coupled fashion, but i'm not too sure.
Regards
"We will have to wait and see".
