interference between axle and suspension
milkyway
milkyway
please help me in figuring out how to determine the whether an axle would interfere with suspension..i am fabricating a vehicle.the suspension is independent double wishbone a arms and the axle has two coupling, one rubber and then a cv shaft..urgent help required..
Jersey Tom
Jersey Tom
Re: interference between axle and suspension
CAD. Use it. The whole idea of designing it ahead of time is so you can pick these problems out, rather than just "build it and see what happens"
West
West
If you want to skip the CAD part, build a mockup of the chassis. As a member of a former Mini Baja team the template for the chassis is fixed. The rules were a little more liberal when it came to engine mounting points. Once we got the engine + drivetrain stuff we did a mockup of engine placement + CV shafts, and designed the suspension points accordingly w/ engine mounting points.
A bit rough, but steel was free, and the car handled fine. Ironically it was the front suspension arms that needed more reinforcement as one of them snapped during compression (after a 30 ft descent)
Bring back wider rear wings, V10s, and tobacco advertisements
riff_raff
riff_raff
milkyway,
Front or rear? Rear is easier than front, since you only need to worry about full bump/droop, instead of bump/droop plus left/right steering lock.
You also did not mention what type of spring/dampener you plan to use. A pushrod & rocker arrangement will be easiest to package with regards to axle clearance. But whatever you do, design your suspension geometry so that all the structural members are loaded in tension/compression, and the attachment/pivot points are loaded in double shear. That will make the unsprung suspension structure the lightest and stiffest. In other words, don't locate your spring/dampener attachment to the a-arm such that it puts the a-arm in bending.
Finally, make sure your CV joint spline/stub axle/flange has plenty of plunge clearance for the axle at full bump/droop.
Good luck,
Terry
A: Start with a large one!"
