Grid Penalty Question
gcdugas
Suppose a driver qualifies in 5th and has a ten spot penalty hanging over his head, so he is demoted to 15th. Another driver qualifies 10th and has a 5 spot penalty hanging over his head... and he gets 15th? Who goes where?
Innovation over refinement is the prefered path to performance. -- Get rid of the dopey regs in F1
Paul
Re: GRid Penalty Question
The order will be the same, as the chronological order of incidents for which the penalties were given. For example, if Vettel and Barrichello qualified 1st and 6th, Vettel would have started from 11th, because he was penalised for Australian incident.
Checked the rules, actually it seems to be the opposite. :oops:
Once the grid has been established in accordance with a) and b) above, grid position penalties will be applied to the drivers in question in the order the offences were committed. If more than one driver incurs a penalty under Article 28.4a) or Article 28.6a) preference will be given to the driver whose team first informed the technical delegate that an engine or gearbox change will be carried out.
Hail22
144
Re: Welcome
Houstonfef wrote:l]
DO NOT CLICK THIS LINK IT HAS BEEN BLOCKED BY OUR CITRIX SERVER AT WORK!
This is a malicious webhost.
Gilles Villeneuve
Gridlock
30
Re: Grid Penalty Question
Maybe remove the link from your quote then? ;)
#58
