LAUNCH
AUSTRALIA
1.New front wing
2.New rear wing
3.New front wheel rim shields
4.Small sidepod panels were added
5.Sidepods - Exhaust area
6.Rear floor
FRONT WING
1.2009 regulations command that the central part of the front wing (500mm width ) must consist of a single element and must also conform exactly to the thickness and chord specified by the FIA .
2.Τhe two outer silver extremities ( only for the two of the four profiles ) are bending slightly upwards to create a gap between the wing profile and the ground in order to reduce the pitch sensitivity of the car at high speed
3. The double red colored movable curvy elements offer the best compromise between drag and downforce and improve the airflow towards the inside of the front wheels .
4. The support of the moveable panels also reveals that only the upper element of the wing is adjustable by the driver. The driver can operate that element by 6° from his steering wheel, activating an adjuster built into the end plate.
5.The neutral shaped elements probably contain the electronics responsible for moving the front panel by 6°
6.Gurney tabs
7. The front wing end plates curve inwards instead of outwards . The additional element directs air around the outside of the front wheels.
8. The Venturi Channel remained
Portimao – January testing
Jerez - February testing
REAR WING
1.Double pillars connecting wing to chassis
2.Gurney flap
3.The main profile is bending upwards in its central part to increase downforce production on its extremities close to the endplates .
4.The flap is separated from the rest of the endplates by a deep cut so as to provide a cleaner exit for the airflow under the main sculpted profile .
5.The horizontal shark gills reduce turbulence generated by the impact of the airflow where they attach to the main profile
