We all have fond memories of races held at Spa, Monaco, Imola, Suzuka, Hockenheim (the real one); they all had distinctive character and were something to really look forward to. That somehow seems to have gone. Bare with me as I try to explain the reason.
After much research and personal interest into F1 circuits I've come up with a number of criteria important to F1 circuit design.
1. Uniqueness
It may seem obvious but it seems to have escaped Herman Tilke. If you think of Spa, what is the first thing you think of? You, like myself, probably think of the 200mph blast from La Source up to Les Combes through the Arden. Imola? The Varianté Alta chicane hopping and Aqua Mineralé sliding are what set its apart. Suzuka has Spoon Curve and 130R and Hockenheim had the 220mph knife-edge wide black-top curving off into obscurity. And finally Monaco has Grand Hotel Hairpin and the Tunnel. Each circuit is remembered for its own unique design, not the racing in particular.
So on that note, a circuit should be designed with spectacular scenery (be it natural or otherwise) rather than trying to create "overtaking opportunities". You don't need overtaking opportunities when you are watching someone slide through Pouhon in the wet. This brings me on to my 2nd criterion.
Circuit maps for all the Tilke tracks:
They may look difference to the casual eye but they all contain the same generic components:
- 1km straight
- followed by a tight corner
- slow-medium speed corners
- 1 or 2 high speed corners
- little elevation change
2. Nature-determined design, not synthetic.
In recent years with the Tilke-dromes we've had several instances where a cheap, sparse area of land is completely flattened and the builders set about creating a "world class racing circuit". You cannot fool a real fan. A racing circuit should be a ribbon of tarmac draped over the natural landscape with as little human interference as possible. F1 is supposed to be man against the environment in the best machinery - if you just make the track to suit the cars, where is the challenge?
What is more breathtaking:
Or:
Does anyone really care about how many overtaking moves are made on what's basically a car park? I know which I'd rather watch.
3. Elevation Change
This is something distinctly lacking from the Tilke designs and despite there being some in Turkey it isn't enough.
For instance we have Spa, Imola and Brazil all with quite severe elevation change over the course of the lap and they all bring spectacular racing. It really does make a difference to the viewer. The newest addition to the calender, the Yas Marinas circuit in Abu Dhabi features zero elevation change and as such, lacks all character. It doesn't matter how many challenging corners you have, if you don't have elevation change, you're done.
Since there are a number of engineers on here, I thought I'd create an expression for us:
Where:
T is Track success
U is the Uniqueness coefficient of the race
Delta E is the change in elevation
I.t is Herman Tilke involvement
S is the number of 1 km straights
P is the Prestige coefficient of the race
4. Distinct Sections
This one may not be quite so obvious but I think it is equally as important and I only just remembered its importance today when racing rFactor online.
What do I mean by Distinctive Sections?
Here are two Tilke tracks that actually show sections within a track:
They are areas on a track that flows/has similar corners (or straights). This may seem irrelevant but anyone who has played a racing game will know what I mean.
Two Tilke tracks that don't have sections:
Both are basically one long section. This makes the track rather expansive and boring - lacks intricacy.
There are old circuits that definitely feature this:
So, this is the 4th criterion that must be taken into consideration when designing a racing circuit. Just think about some circuits that don't have sections (or at least fairly obvious ones) and you will see how they aren't so fondly remembered.
