Variable Camber
mike
mike
Variable Camber
i have only recently came across a system that design to maximize contact patch and equalize the temperature of in and outside of a give tire by changing its camber during the cornering (like bikes)
however the only info i manage to get is a few websites describing the system and a official site that no longer works.
http://horsepowersports.com/oncamber-va ... ng-system/
http://www.carbibles.com/suspension_bible_pg2.html
can any of you shed some light on this
al_kar
al_kar
Re: Variable Camber
Camber changes can be achieved by clever suspension geometry and without using servos that add weight to the car.
mike
mike
Re: Variable Camber
true but it achieves camber only during turning as the wheel have nearly zero camber in the straight and upon turn in it will change the camber infavor of the direction
it basically means that it can achieve a perfect setting for every corner, braking and acceleration every time and it also prolongs the life of the tyre
i got a feeling that this does the job of a caster angle but you rarely see motobikes turn in with the front wheel(which has caster), they use the lean on the bike to turn
FLC
FLC
Re: Variable Camber
I am pretty sure Mercedes had a concept car with this feature a few years ago, not sure about how it was achieved though. I'll try to look it up.
FLC
FLC
Re: Variable Camber
Wasn't very hard to find. I'm not sure what exactly you're after, but it was called "F-400 Carving" and it had adjustable camber on both outer wheels when cornering. It was done in 2002, by the way, and it required special tires with a more rounded shoulder.
You can read more here
al_kar
al_kar
Re: Variable Camber
mike wrote:true but it achieves camber only during turning as the wheel have nearly zero camber in the straight and upon turn in it will change the camber infavor of the direction
Bikers do that because of the centrifugal force. They need to lean otherwise they will fall. In a car the equivalent is an active suspension (like citroens for example). Not the camber changing servo. But i insist, there is no need to put on heavy equipment, like servos or pushrods, in a car to achieve camber change. It can be done passively with the geometry of the suspension.
FLC
FLC
Re: Variable Camber
Up to 20 degrees? with regular tires? or would it still be a bit of a compromise?
Scotracer
Scotracer
Re: Variable Camber
I thought about such a system a few years ago but just left it at that. It could have been a way to fast-forward my engineering career #-o
Powertrain Cooling Engineer
Ted68
Re: Variable Camber
Designer Len Terry had a wonderfully simple system back in the 60's. Dig up some of his old books.
Heaven: Where the cooks are French, the police are British, the lovers are Greek, the mechanics are German, and it is all organized by the Swiss.
Hell: Where the cooks are British, the police are German, the lovers are Swiss, the mechanics are French, and it is all organized by the Greeks.
Belatti
Belatti
Re: Variable Camber
al_kar wrote:... But i insist, there is no need to put on heavy equipment, like servos or pushrods, in a car to achieve camber change. It can be done passively with the geometry of the suspension.
Can you tell us how? :)
If you dont wanna tell us here, I would pay you thousands of dollars if you can design for me a car with your passively suspension geometry that can have 0° camber in the straights and, while rolling, controlled negative camber in the outer wheels and controlled positive camber in the inner wheels.
mike
mike
Re: Variable Camber
al_kar
do you even know what you are talking about?
bikes lean to achieve better speed, you can turn the front wheel to turn but it will be really slow.
this system is not about the lean of the car its the lean of the tires on the car. it does not require the car to have a weight transfer before it reacts, it uses the lean of the tyres to turn quicker
Carlos
Carlos
Re: Variable Camber
A little OT. But slightly related. :D
Belatti
Belatti
Re: Variable Camber
tomislavp4
Re: Variable Camber
[quote="Carlos"]A little OT. But slightly related. :D
That´s a nice system, but it has it´s drawbacks. The most obvious would be the aero one, I mean, the shocks are exposed and the "thingie" that they´re bolted on is also exposed giving a rather big drag penalty. Than, ofcourse, the vehicle needs to be narrow and have a big ground clearance...
DaveKillens
DaveKillens
34
Re: Variable Camber
http://scarbsf1.com/renault_opt/Renault_OPT.htm
