Choosing a tyre size for a given Rim width
bizadfar
bizadfar
Hey guys,
long time no post here as I've been mostly concentrating on my own street/track (dual purpose) car.
It's time for new rubber and I'm using 8" wide rims all round.
the standard was 225/45/17 (load rating: 91).
I went with 235/40/17 (load rating: 94) to lower the center of grabity without further distorting the suspension geometry. 235/40/17 is not common here and tyres can cost up to 3-4 times as much.
I'm considering going on 245/40/17 95 load rating.. but is there such thing as diminishing return?
Disregard fender/control arm clearance as well as increase in drag.
flynfrog
Re: Choosing a tyre size for a given Rim width
stock tire size on my car was 225 60s I believe I now have 245 45 on there the problem I have is the tires is pushing the limits of rim width. Its hard to get the tires to maintain its shape across its width.
Super racing
Super racing
your best bet is to go thru all the options and info at tirerack.com
plus they have a good selection DOT approved comp tires and slicks
http://www.tirerack.com/tires/sizes/res ... iameter=17
I usually go as wide as I can(maintaining a good balance) and no lower profile than 40, but then again I get alot of free tires from my used tire connection, but I only use those for testing.
check the recommended tire widths for your rim width
