I am building my own closed cockpit style "prototype" sports car. It will resemble the latest Lola/Judd that Sebah racing runs. I am stuck on a few geometry subjects in the rear of the car. Running caster in the rear of a double A arm suspension? Some call it trail. Should I? if so, how much and why? Static or so many degrees at say, 1" compression..?
Question #2 If I'm running 2" of static ride height and were to set up a push rod assembly for the dampers, would you run 1:1, digressive or progressive rates from the wheel to the shock/spring & why? I "think" I would like to run lower spring rates and keep the ultimate force up..? Finally, I have been to Le Man a few times and looked over the wide variety of pick up points for the suspension. Is there a good logical reason for the A arms to go forward to the center of the car vs, even spread or towards the back of the car. Standing at the RR looking at the transaxle, I am currently laying out the upper and lower A arms to run 2" behind the axle and about 22+" forward, just in front of the motor; like an old GT 40. Thoughts??
Thanks!!
