djones wrote:This whole understeer thing...
Is it simply a case of the back end is a lot better than the front and therefore has more grip causing understeer?
yes
the axle that has more grip will tend to stick whereas the axle with less grip will tend to slide .In case of understeer the fraont axle has less lateral grip.
what you do not know is :is the less grip coming from
verworking the front tyres ,tyres getting hotter than rears loosing grip (due to chemcal reactions etc + gaining internal pressure reducing contact patch size leading to more loss of grip)
or is it underworking of the tyres ,no grip due to cold tyres. if this is happening very soon the case will swap around as the front tyres will sometime get hotter build up grip but at this time the rears which had already reached their working window inevitably will overheat and you will be stuck with oversteer...
Plus: a car with 7hundred something horsepower will always be poweron oversteer ,it should be possible to break traction with overenthusiastic throttle squeeze...
so for early throttle on corner exit you NEED some understeer or you will have to wait until the car is straight.
so what we are talking is Corner entry behaviour really .the car should be very responsive and willing on the verge of being eager to change direction, whereas a understeering car on corner entry will not change direction before slowing down sufficiently.(Because the rear has so much more grip ,you are on the brakes anyways ,so you have to wait for the speed to come down to be able to turn ...so the guy who does trailbrake -turnand brake is really at a loss with this behaviour
of the car.Of course you make up ground as you can instantly floor the throttle when you have turned the truck into its new direction ,so the time lost is not as dramatic as it seems but if its not your style you can´t do much with the car in terms of manipulating it .
and of course killing the rear grip is easy but then you are on the right balance but on a lower level of speed..not good.
