I have been busy blogging away looking at the different points systems that have been used since 1950, how the points were distributed and how fair each system was. This has been inspired by the change in the points system in 2010.
First, I looked at how points have been awarded since 1950. The original post is here but I will provide a summary for you guys: http://f1numbers.wordpress.com/2010/02/ ... 1950-2010/
The logic behind the new system is that by increasing the amount of points scored for a win and by increasing the gap in the amount of points for each position, overtaking would be increased as drivers have more incentive to fight for a win.
The new system, in case you did not know, is 25-18-15-12-10-8-6-4-2-1 from 1st down to 10th place.
But will it do this and what exactly is the gap between each position worth?
The first part of the question is speculative and my personal opinion is that it won’t – simply because the cars cannot overtake due to a heavy reliance on aero grip and a number of circuits being unsuitable for F1 cars (including some of the new ones). Increasing the incentive cannot and will not fix this…
However, the second part of the question is essentially a stats question and therefore one I can easily tackle in this post. Therefore what I will do is make a graph of each points system used in F1. I will then use these graphs to display each system separately and show in that particular points system how the points are scored in proportion to a win (100%)
Clearly a number of different systems have been used over the years, so it will be interesting to compare them to each other to see which systems reward drivers who go for wins and which systems reward consistency more. First, let’s have a look at the new system compared to the other systems in terms of amount of points scored:
What we see here is that until 2002 we had a nice system with about the same amount of points distributed through the field, and then in 2003 the ‘consistency formula’ meant that a lot more points were awarded. But 2010 is something else entirely and is two and a half times greater than the consistency formula! This means that the distribution of points is a lot more generous and also any records to do with most points scored will effectively become meaningless!
Let’s take another look at these systems and this time, focus at how the points are scored in proportion to the sum of all points available (from the previous slide):
Again, until 2002 the systems used were quite fair in awarding around a third of the available points to the winner, about a quarter of the points to second place and decreasing proportionally. The 2003 system instantly devalues a win by only awarding around a quarter of the points to the winner, and then a fifth to second place. The 2010 system does not change very much from this, which is interesting that considering one of the aims was to make a win more valuable. In fact, in the 2010 system a win is less valuable than in every other system!
But what about other possible systems? I have always had an idea of how to make a system that rewards winning, so I have decided to compare this to the 2010 system along with some other crazy ideas for points systems:
Are these good ideas or just silly? I mean, if we are prepared to throw out the records for points scoring, then why not use a system where loads of points are awarded for a win anyway?
In my next post, I’m going to look at how fair the points systems have been since 1950 up until 2010. Stay tuned for that, but in the meantime let me know what you think of the proposed systems, or if you have any better ideas
//RubberGoat
